Menzerna Power Finish
If you have any specific questions on the product, please do not hesitate to ask. For lighter scratches, I'd start off with a white polishing pad and assess your results from there.
Keep us posted on what you think of it if you give it a shot.
Cheers,
George
Perhaps you should post a picture of your car with the focus being the paint in the sun. We'll be able to better diagnose that way. A trained eye may see things differently.
Power Finish (PO203S) - (M) this is a one-step scratch remover polish is formulated for CeramiClear or other ‘Hard’ paints. It will remove 2500 grit, cut 3.0-gloss 3.5, is formulated as a quick way to polish out light flaws and amplify the paint’s gloss. Designed for European, OEM automakers using scratch-resistant clear coats, but as other automakers begin their switch to high-solid-content clear coats (Mercedes-Benz, Maybach, Audi, VW and Porsche plants in Germany, Volvo in Sweden, Renault in France, Ferrari and Fiat in Italy and here in the US at Daimler-Chrysler and General Motors Corvette
With a single step polish once you see it has just started to break-down, either clean your pad or replace it with a fresh one and then continue at the same RPM you left off at, break-down the rest of the polish, and then continue to burnish the paint surface.
As a 2-Step System - Power Finish PO203S is an ideal polish for all ‘hard’ clear coat paint, after a wipe-down process it can be followed with Nano Polish (PO85RD 3.01) using a black pad for lighter imperfections, or for burnishing the surface for even more depth and gloss.
While technically a final or finishing polish in the same category as PO106FA, PO203S Power Finish offers substantially more cutting power, In fact, it is just below Menzerna PO83 Super Intensive Polish in its ability to remove moderate to mild swirls, water spots, and light scratches, and then it burnishes the paint to an ultra high gloss
An extract from one of a series of in-depth, unbiased detailing articles © TOGWT ™ Ltd Copyright 2002-2009, all rights reserved.
Ferrari
08-24-2015 04:35 PM
