Mr. Clean AutoDry Car Wash
I noticed that this car wash product hasn't been covered. Just wondering what some peoples opinions of this product are...
It has a filter for the water, and special soap that when used in conjunction is supposed to give you a no-spot wash, with no drying required...
Couple of problems. The soap is very strong. After one wash, it stripped off all the wax and the paint no longer had beading action. Second, the pur filter is so small, you basically have to trickle the water on the car to make it effective. And you'll probably get about 2-3 rinses out of the filter before it has to be changed.
For someone wanting something very quick and easy it's an OK tool. You will still get spotting and you can't simply let it air dry. Nothing to this day can take the place of a simple hand wash with some good products.
It's one of those products that's good in theory, but not in practice. It's simply a pur water filter in the nozzle and the nozzle houses the soap as well. I've used it a few times before to see what it can do. You rinse your car, spray the soap on the car, use a wash mitt to agitate the soap and clean the car, rinse with water, and then turn the dial and rinse with the "filtered" water.
But to reiterate what everyone has said, the CR is the only system on the market that works as advertised and is portable and small.
http://www.glisteningperfectionstore...High%2C/Detail
My experience is consistent with the comments above. The Mr. Clean system is simply too small and the flow rate is too low to give spotless results. Also, the soap provided with the system leaves a film on glass that is very noticeable in humid weather.
I didn't want to put the product down...there's a market for everyone. Nothing wrong with that.
I was drying my car just two days ago, and 5 minutes into the dry i was thinking... There's got to be a better way then this.... It's exhausting and the water in the cracks and crevices is never ending!
Thanks!
I just went to Home Depo & get a 2 stage water filter & softner, it cost me just about $100 & the filters last a very, very long time. over a year for the filter, & about 6 mo for the softner.
Very little water pressure loss from it, I'd say 5-10%. You can just just move the tops to shut it off.
Moe, I'm confused about the different models of the CR Spotless system and which one would be right for me - the wall mounted unit and the unit without wheels are off the list, but of the 2 models, (one with the larger tanks and one with the smaller tanks) which one would make more sense? I wash my 360 once a week and that's basically it... Any advice?
Thanks!
Thanks!
Thanks!
Thanks!
https://www.6speedonline.com/forums/...y-special.html
Mike, will that dry a car spot-free if left to dry and not wiped off? From my research, water softeners don't reduce the PPM count, they merely exchange the Ca and Mg ions for Na and Cl making salt water. It softens it from the hard minerals, but it won't reduce the actual ions causing water spots. I use to use such a system and it was better than using tap water, but it would leave a bit of spotting behind. Also, deionized water is based on the volume of the resin...the greater the volume, the greater the flow of water and the longer the system will last. It doesn't look like there's much volume of resin in the right cartridge.
That being said it will not leave the car spotless. But it really cuts down on the spotting, & it seams to be easier to dry. Since I'm filtering the water, it also removes chlorine, & other crap, so I don't have to worry about any dirt in the water to scratch the car.
I have no doubt the CR system is better, it's just to expensive for me, & I don't like to change the resin all the time.
No, it just cuts it way down, & when there are spots, they are much easier to clean off. A quick QD will take them off.
PorscheEnthusiast
11-13-2015 02:23 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
