Discounts on Chemical Guys, Menzerna and ClearKote as well as a Flex Buffer Promo
20% off Chemical Guys
No coupon code is needed, just shop and save 20% off on all Chemical Guys products! This offer expires 3/31 at midnight EST.
All Clear Kote and select Menzerna Products are at Closeout Prices! Here is a complete list of the products that you will find big discounts on:
Menzerna
Menzerna Finishing Touch Glaze (FTG)
Menzerna Full Molecular Jacket (FMJ)
Menzerna High Gloss Acrylic Shield (HGAS)
Clear Kote
Clear Kote Carnauba Moose Wax
Clear Kote Fine Grade Clay Bar
Clear Kote Quik Shine (QS)
Clear Kote Red Moose Machine Glaze
Clear Kote Vanilla Moose Wax Hand Glaze
Last Chance to Save - Flex Promo
On April 1st Flex is forcing everyone to raise the price on the Flex XC 3401 VRG. Before we have to raise the price we are offering you the Flex XC 3401 VRG at the same old price of $299.99 plus you will get two free pads of your choice (expires 3/31 at midnight EST). Just use the coupon code FLEX2 after adding the Flex to your shopping cart and you'll get the two free pads. This offer comes with 2x White 6.5" pads but you can select any pads you'd like by adding a comment in the comment field while checking out. To read more details you can visit our Flex Blog Post.
March Specials (expire 3/31 at midnight EST)
DI Microfiber Waffle Weave Drying Towel
- One of the best options for drying your vehicle and most commonly used by professional detailers
- The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
- Our microfiber waffle weave towel has silk edging to minimize adding imperfections
- This towel can hold up to 5 times its weight with water
- We recommend using the sheeting method prior to drying with the towel for maximum efficiency
- Always wash your microfiber products prior to first use
Meguiar's Ultra-Cut Compound M105
- Very effective at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
If you have any questions about these deals or if you'd like a recommendation don't hesitate to ask.
George
PelicanParts.com
09-01-2015 02:36 PM
