Help asap!
Old 06-10-2010 | 08:45 PM
solekeeper's Avatar
solekeeper is infamous around these parts
Help asap!
Guys, since autopia is down, I'm in need of a quick ref.
I'am wetsanding with 2500 grit, I will be correction with a rotary. I already have the materials except for pads.
I have discussed with several members over on autopia to use LC pads.
However, which type of LC pads should I use? (Hydrotech etc.)
THanks!
Old 06-10-2010 | 08:54 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
CCS pads work very well, and will help keep the heat down. If you're polishing out 2500 grit sanding, it should come out fairly easily.
John
Old 06-10-2010 | 09:02 PM
solekeeper's Avatar
Thanks, and that is for the rotary right?
My steps will be
m105-Maroon Solo Wool
m105-orange
m205-White.
UF
Old 06-10-2010 | 09:03 PM
detailjohn's Avatar
Correct. Looks like you'll be in good shape.
Old 06-10-2010 | 09:08 PM
solekeeper's Avatar
Thanks john.
One more quick question before I place this order,
can you explain the difference between these
http://autogeek.net/lake-country-beveled-edge-pads.html
and the ccs you recomended
http://autogeek.net/lake-country-ccs-pack.html
thanks once again!
Old 06-10-2010 | 09:18 PM
detailjohn's Avatar
If you're correcting with a rotary, I wouldn't recommend using such a small pad. Get a 6.5" CCS pad. Site sponsor Moe has them on the shelf.
John
Old 06-10-2010 | 10:01 PM
solekeeper's Avatar
Jeez, I forgot the size of my rotary.
Wonderful..
But in terms of cutting aility, do the ccs pads differ much from the flat pads?
Old 06-11-2010 | 12:07 AM
MoeMistry's Avatar
Premium Sponsor
Wonderful..
Sorry for the delayed response...the CCS pads do a better job of dispersing the polish/compound on to the surface. The nice thing about the curved CCS pads we carry is their ability to contour curved areas of body panels.
You seem to have a good routine...orange and white pads should work well for you.
http://www.glisteningperfectionstore...ols/Categories
Old 06-11-2010 | 07:33 AM
solekeeper's Avatar
thanks alot moe! Guess I'll go with the CCS pads over the flat.
So that's it, the ccs curved is basically the same thing as the flat pads, but better for angles?
(I'll likely need this for a 76 Countach)
Old 06-11-2010 | 08:34 AM
MoeMistry's Avatar
Premium Sponsor
Pretty much. Let us know how the Lambo turns out.
Old 06-11-2010 | 04:40 PM
solekeeper's Avatar
Moe, thanks alot for your help! Will do! Plan on having pics..
Old 06-11-2010 | 09:02 PM
MoeMistry's Avatar
Premium Sponsor
You're welcome...look forward to seeing the pics.
Old 06-11-2010 | 11:04 PM
solekeeper's Avatar
moe! One more quick but very silly question
I don't have my box that says the size of the buffer (makita) however, on the plate on the buffer it says 7 inches.
Which size lake country should I go for?
Old 06-12-2010 | 07:08 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
is that a stock backing plate that you have if so you have the 7 inch one.
you would need to pick up a 6 inch backing plate for the 6.5 inch pads.
what out with the ccs pads as they tend to leave pig tails, make sure they are a clean up after a few passes. or just change up your pads. we noticed this a few years ago and stopped carrying them for the flat pads.
just some insight.
Old 06-12-2010 | 11:04 AM
solekeeper's Avatar
Yea, stock backing plate.
Thing is, I measured the plate and it's about 6.5?
