Polishing with Menzerna SIP and Super Finish: How many Pad "steps"?
OK a few more dumb questions :P I'm hoping to make some real progress over the holidays. I've taped my sister in law's SAAB down the middle so I can get some before and after shots
If I use the wool pad with SIP, can I go straight to an orange or white pad with the Super Finish? Or do I need to go from wool, to yellow (SIP), to orange (SF), to white (SF)?
Also, I use IPA between each stage, but I've not happy with IPA prior to inspection as it seems to streak/haze/collect dust easily so when I shine my worklike (the $20 700 watt super halogen light from home depot), I don't really see a "mirror" finish with which to judge the results. Should I use a quick detailer or Meg's final inspection or the Menzerna final inspection product?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
If you get streaking with IPA, that means you didn't break the polish down enough and are rubbing polish with IPA. You know you're done with polishing when the surface is almost transparent and you can see your reflection. Top Inspection would work fine as well.
You may want to consider coming down for a private tutorial Joe since you've invested good money in the proper tools. An hour or two will shed a lot of light on everything and you'll walk away with a wealth of knowledge. We could even do a group tech session if enough of you are interested.
manfred@loma_wheels
09-02-2015 11:22 AM
ECS Tuning - VW
09-02-2015 09:03 AM
