Soap recommendations
I have recently started using my power washer when washing my car. It has a low pressure nozzle and a tube that comes off of the washer that allows me to drop the tube right into a soap concentrate or something like that. I'm looking for recommendations on foaming soap or something like that. So far I've only found Maxi-Suds II SUPER SUDS SHAMPOO, but I'm looking for recommendations on what else is available. Also if you have a recommendation on a soap that I could use with a bucket of water and microfiber sponge as well.
Thanks,
James
Thanks,
James
Assume you mean that you have a foam cannon-type attachment for pre-washing?
I don't see any reason to use the expensive stuff for that. Buy a jug of Meguiar's Gold Class at Costco for $9-12. Will last forever.
For the sponge/bucket step, I use Chemical Guys Citrus Wash when I want to strip the LSP and Lusso Oro for maintenance washes.
Thanks,
James
Thanks,
James
Best advice, if you're going to use the OTC soaps, simply spray wax or wax the car often. Otherwise, a simple wash bucket method of washing is the best IMHO. However, for you east coast folks, I can definitely appreciate the need for a soap-soak step with all the harsh weather. So perhaps buying the cheaper soaps and just spray waxing is the best option.
You can probably buy the soap in the gallons at a costco or order it from one of the vendors here that would sell in that quantity.
+1 for the Meguiar's Gold Class. I use it with both a Gilmour Foam gun and a Honda gasoline power washer. Dilute the Meguiar's Gold Class with one part water to one part soap and blast away. It doesn't remove your LSP and does a great job of removing grit/dirt/salt without creating swirls in the paint.
Is it me, or is he using some really high pressure when rinsing the car off? I've got a mini and I don't even use that much pressure on it when rinsing.....
http://www.youtube.com/watch?v=nq6t8...eature=related
SpeedShine is more of a detail spray than a spray wax. But if it's working for ya, then keep using it.
Yikes!!! I'm betting that's the whole wash. I cannot tell you how much more microscopic dirt is probably left on the paint if that's the only thing done. Nothing beats a simple wash with a mitt and bucket IMHO.
Actually using a good quality soap that's not too harsh is very important. Say you spend hours polishing and waxing your car. Do you really want to wash away the wax and the work you did to save a few bucks on soap? If the soap is not gentle, it'll strip the wax off prematurely. That's why the higher quality soaps not only last longer because you use less, but they also keep the paint looking better longer because they don't strip wax off as quickly as lesser quality soaps.
Wow, using a water blade after just a touchless pressure wash is the perfect recipe for scratching the paint finish. I use the PW for a pre-rinse, deionized water source with CR spotless and a three bucket wash technique and still fear touching the paint for drying. Hence use the air-blower. I know I am **** but thanks to Moe (I got my PW, CR spotless and blower from him) car washing is a treat for me every single time. I use Griot's soap which is very mild and the beading from the wax coat lasts for a good three to four months despite my once a week wash.
Studio RSR
Lamborghini
11-10-2015 07:00 PM
Midcont
09-11-2015 08:29 AM
