Premier 2011 GT2 RS Full Satin Guard Wrap + Moar!
What we're doing to it? Lots - subscribe to thread!!!!
Premier Protective Films
ClearGuard Alpha PPF, Spectra PhotoSync Nano IR & CeraLuxe IRD Tint, Coatings
www.premiermobilegroup.com
Sharing our Passion on Youtube: https://urlgeni.us/youtube/Premier
Facebook: https://urlgeni.us/facebook/Premier
42630 Christy St, Fremont, CA. 510-623-1308 sales@premiermobilegroup.com
Ok fine....here's a few more!!! Here's what we're doing to it:
1. Satin Guard™ full vehicle protective wrap (thick as paint protection film / clear bra)
Example: http://www.teamspeed.com/forums/997-...turbo-pdk.html
2. Diamond Cut IR™ Nano Window Film - Infrared rejection at 94%
Example: http://www.teamspeed.com/forums/deta...t-ir-tint.html
3. Escort 9500Ci Premier Stealth Installation (Radar detector + Laser Diffuser System)
For those who may be unaware with what the Passport 9500Ci is, it essentially is a custom radar detector + laser shifters (for Lidar guns).
Customer will drive this rocket fast, so it is imperative for him to have the display and control module hidden best as possible without compromising the interior. We made a custom carbon cover to better match the interior carbon trim pieces. Below are the results:
Here you go, pictures were finally uploaded. Enjoy!!!! Again, this is what we did for this beautiful white 2011 GT2 RS:
1. Full Vehicle Satin Guard™: A revolutionary film with DualTone Technology built into its construction. Indoors, the clear satin protective film exhibits a satin matte finish while outdoors the metallic flakes show through.
FAQ:
Q: How is this different from the matte and "satin" vinyls?
A: The product is actually nearly as thick as traditional paint protection films (clear bra @ 8mils thick) while vinyls are only 1.5-2.5 mils
Q: How do you maintain it?
A: This product is actually easier to maintain and simplifies the entire process of cleaning and detailing the vehicle. No waxing or polishing, just wash. The product is also very resilient to chemical etching.
2. Diamond Cut IR - 94% IR rejection / 99.5% UV rejection. Shades available 73%, 63%, 50%, 33%
3. Escort 9500Ci TruStealth Installation - full custom stealth install. Look for the diffusers in the photos. Very difficult to spot.
FAQ:
FAQ:
FAQ:
More more more.........
Diamond Cut IR 73% going on the windshield
Let MOAR continue!!
Let's do this - More more more of our Satin Guard™ going on this stunning white 2011 GT2 RS (nope, not clear bra - Satin Guard™ Protective Films):
By the way, see if you guys can spot the Passport 9500Ci Laser Diffusers (yes, we did remove the front and rear bumper to get a flush mount of the radar detector and laser diffuser system). For the rear diffuser, we did not install the unit like most of the ones you would see on the market where it is just bolted on to the license plate frame screws. We installed it in a way that makes it integrated with the vehicle, yet would not interrupt the performance of this system
Satin Guard™'s Dual Tone Technology (different sheen based on varying lighting is obvious in these photos). You can clearly see the satin white glowing in direct sunlight.
Experience speaks for the work!!! On top of that an extremely talented team of craftsmen.
Again, we wrapped this 2011 GT2 RS in original white with Satin Guard™. How does this product compare to others on the market? FAQ below:
A: There is a specialized cleaner and soap solution, both which are inexpensive. Regular car wash soap works, but tends to leave oily streaks. The wash soap and cleaner works much better as it is designed to clean the pores of Satin Guard™
Q: Does it scratch like paint?
A: In short, no it does not swirl like paint. The product does have extensive protective capabilities like clear bra. However, it can be damaged like any film on the market
Q: I've heard of other satin vinyls. How does this compare?
A: Satin Guard™ is 2-3 times thicker than the various iterations of "satin" vinyl and films on the market.
Q: Will it damage the paint if I have to remove it?
A: If it is OEM paint, applying Satin Guard™ is fine. However, with aftermarket paint, it is possible that the paint would lift with poorer paint jobs (MAACO, Earl Scheib, etc....to name a couple).
Q: How much to have it installed?
A: Satin Guard™ is a highly customized application. It is a requirement for both Satin Guard™ and Clear Bra apps to have any new customers set up an appointment for consultation to obtain a quote.
Q: I'm not local to you. Would I be able to purchase the film from you?
A: Yes. As a matter of fact, we are already selling / shipping the film out stateside and globally. You would need to source out an excellent paint protection film installer for this.
Q: Can my local vinyl guy do this?
A: This is a highly skilled craft. To get it to the level in our photos, it is most unlikely you would be able to locate an installer that would be able to replicate the install 100%. Comes down to your needs and standards. With vinyl installers, especially if that is their core business, Satin Guard™ and clear bra installs are quite different. Search for a professional clear bra installer to obtain better results
This beast just came back to us recently........all while we are running through our renovations. Customer wanted to change the Diamond IR Nano tint at 50% changed out to 33% for a different look. Enjoy!!!!
