Birthday Gift
72 -- Buy the CR Spotless. You won't regret it. The fish smell thing is WAY overblown. This is a quality unit that will just about eliminate swirls on your car's finish. Also, you cut your wash time in half. I agree with Moe that the cost works out to a few dollars per wash. In other words - NOTHING. Go for it, and Happy Birthday.
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
Moe: question re this topic.
Hi Moe:
I will post my question here since the CR Spotless and the "fishy" smell topic is covered in detail here.
I too noticed the distintive smell from the water. I did not use my CR for over 2 months, and I knew that my resin needed replacement soon. I do not empty out the water from the canisters after every use, and so it sat there for that time. I was surprised to see that the output PPM was over 200 from the CR!
So my questions are:
Thank you for your input.
- Does leaving water in the CR unit shorten the life of the resin?
- Is the only reason you empty the canisters is to minimize the smell and avoid potential algae build-up?
- Can valves be retrofitted onto the canisters to facilitate emptying?
ECS Tuning - BMW
BMW Vendor Classifieds
09-24-2015 03:44 PM
