Birthday Gift
![Wink](https://www.6speedonline.com/forums/images/icons/icon12.gif)
Ok my birthday is coming up and wife wants to get me something for my car:
![](http://img.photobucket.com/albums/v435/Karnotaur/IMG_3683CR2-Version3.jpg)
Own a Porter Cable, metro blower, metro vac and have plenty of wax and supplies. Wash my car weekly.
No real budget since she is spending my $$$, lol![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
So what should I get?
+1...great call Dan. CR will be your best friend and you'll wonder how you ever washed your car without it. It is a water de-ionization filter that allows your water to be pure and have no water spots. Great addition to your detailing war chest.
http://www.glisteningperfectionstore...High%2C/Detail
Get the DIC-20...best value and mobile for around the house as well.
Is this just for final rinse or through out wash process?
If through out wash process can it be hooked up to pressure washer?
If yes to pressure washer what about foam gun, I use Gilmour on regular hose now?
You can use it with a foam gun as well...you'll need much less soap since it's pure water.
I don't a pressure washer but was thinking of a complete set up:
Pressure washer
CR spotless
Foam gun
How would this all go together and what products would work together?
Water supply > CR spotless > Pressure washer > Foam gun ????
CR spotless works well when you have fresh media in the unit. As you use water and depending on the TDS in your local water supply, the TDS passing the filter will continue to go up until it is useless. The media is very expensive and also (especially if you use a powerwasher) makes the water smell like warm raw fish. If you don't use much water and don't wash too many cars per week you might really enjoy it.
It might be beneficial to check with the city (or test yourself) the TDS of your tap water. The higher the number the faster you will go through the media.
TDS = total dissolved solids.
-Justin Rush
-Justin Rush
-Justin Rush
-Justin Rush
-Justin Rush
-Justin Rush
If you get the fishy smell, it's probably because you're not running enough water through the system. How often do you use the CR? If not used for more than a few weeks, it's good to take the resin cartridge out of the unit. Or, just flow some fresh water every week so you don't have stagnant water in the system that can form algae and shorten resin life or get that fishy smell. Another reason for the fishy smell is if the resin is exhausted.
Hope this helps avoid the smell.
Ok so how would the Gilmour go into the pressure washer?
Pressure washer
CR spotless
Foam gun
Pressure washer
CR spotless
Foam gun
http://www.glisteningperfectionstore...zle/Categories
You can purchase a foamer for the pressure washer or use the existing foam feature that comes with most pressure washers. Hope this helps.
I got the CR Spotless system as a gift about a year ago. It is hands down the best detail toy available! Period. I wish I had it years ago. Totally transforms washing your car and makes it a pleasurable experience as you no longer need to worry about getting the car out of the sun and drying it quickly. For me it has totally worked as advertised. No fishy smell here at all.
Adam
Adam
Ya...the CR is pretty much a bullet-proof and effective unit. Not much can go wrong. I do get the fishy smell once in a while; so it's not unheard of. But that's my sign that the resin needs replacing. Doesn't happen too often though. Just gotta pay attention to the meter.
