Leather Care / Light Repair on ventilated seats
Seeking advice, specifically related to the ventilated seats.
Several of us have experienced some abnormal wear & abrasion.
See the topic here: https://www.6speedonline.com/forums/showthread.php?t=244164
Would like to know
1) Recommended leather care products / tips for ventilated seats.
2) Any suggestions for repairing minor abrasions?
If you would, please post on the thread linked above.
Many thanks in advance to all the experts and enthusiasts here.
Would like to know
Perforated finished leather Leather Master™ Foam Cleaner - the advantageof foam over liquid is the minimum amount of moisture, very important for cleaning absorbent and moisture sensitive (Aniline, including perforated) finished leathers. Leather Master™ Foam Cleaner is a solvent free pump action product, which is extremely efficient for the cleaning of general soiling and water based stains.
Scratched or Scuffed finished leather – If the pigment coating is scratched it needs to be repaired and no amount of cleaning and 'conditioning' will make it go away. The surfaces need to be correctly prepped and then a pigment (colour) added. By using this kit from Leather Magic; wipe the leather down with the solution, using the 220 grit sand paper; this will remove most of the minor creases. Apply 3-4 thin coats of pigment (allow to dry between coats) you have the option to spray the final coat with a sprayer (all included in kit) – Leather Magic Repair
Use Lexol leather conditioner sparingly and message by hand. Don't use a hair dryer or steamer on perforated leather. If you need color, use a water based, air-brush application and top-dye like much leather is done originally. My experience suggests it's hard to recommend sanding leather for any reason.
cnebrask
10-03-2024 08:19 PM
pwdrhound
08-23-2015 07:36 PM
abrasion, care, cleaner, interior, leather, leathermaster, magic, master, online, perforated, repair, seats, small, speed, ventilated
