New Product - Lake Country Constant Pressure Pads!
We're very excited to have the Lake Country Constant Pressure Hi-Gloss Foam Pads in stock. As most of you that have ever used a dual action or rotary polisher know, you can never have too many pads to choose from. When it comes to polishing a vehicle, selection is key along with high-quality products designed to get the job done right the first time.
What makes these pads unique is they feature a layer of engineered, instant rebound foam between the pad and the backing plate. The instant rebound foam layer acts as a cushion or shock absorber between the backing plate on the machine and the surface you're polishing. This allows the pad to absorb off-axis motion while maintaining a constant and uniform pressure on the surface. To make it simple, this allows a beginner to achieve the results of a professional.
As you can see below, the rebound foam is super soft and acts as a cushion or shock absorber. The rebound foam absorbs the uneven pressure while polishing which allows 100% of the face of the pad to remain flat on the surface.
They're available in a variety of different sizes and colors, and they're on sale!
04-28-2022 12:38 AM
LiquidElephant
08-27-2015 06:17 PM
Ferrari
08-24-2015 04:35 PM
