How do I choose the right detailing spray?
Hi all,
In my endless struggle to become at the minimum a good detail hobbyist (and clearly I have a long way to go ) how do I choose the right detailing spray. Does it depend in the type of protection (wax, vs non-wax etc.), paint, washing habits, ???
I use Ultima Paint Guard Plus (open to suggestions on other / better wipe-on protections). I wash my cars every weekend and use a detail spray as the final wipe down. I've been using an OTC spray and figure there must be better choices.
Thanks much!
Matt
Thanks much!
Matt
Hi all,
Thanks much!
Matt
Thanks much!
Matt
A spray wax is basically like waxing the car as it contains gloss enhancers, wax, and is designed to protect.
Both are handy to have around. We tell clients to keep a detail spray in the car for when you get hit with bug guts or bird dropping. Use a spray wax after each wash to keep the actual wax rejuvenated and it will make the protection last longer.
My detail spray of choice is Meguiar's Final Inspection. Easy to use, works great, and smells nice.
Spray wax, love Sonax High Speed Wax. It takes a little getting use to, but once you have the technique down, the shine and depth it leaves behind is the best I've ever seen.
Hope this helps.
My favorite by far is Gloss-It Gloss Enhancer. Smells good, goes on well (even on hot cars) and shines awesome. I have tried probably a dozen different ones and it works best. I have converted many to it.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
I think many detail sprays do more than just clean or remove dust. Many actually add temporary gloss and slickness to the finish.
I like to use Zaino Z6, Duragloss FCS, and FK 425.
Quick detailers vs. Spray wax
A Detail spray (QD) is designed to remove fingerprints, light dust, etc. from the paint surface. A typical quick detailer spray is formulated with 80 - 90 % Water, 0.5-1.5% Carnauba wax, 0.1 – 5% Silicone polymer or Mineral oil, so they don’ have the inherent solvent content problems like spray waxes.
A Spray wax contains polymer gloss enhancers, wax, and is designed to enhance surface protection. To enable an organic wax to atomize it requires a high percentage of solvent, which when sprayed will remove and / or compromise the durability of an existing wax or sealant
Both types of products add a somewhat temporary gloss and slickness to the paint surface
Can you explain further? What takes getting used to? What is the proper technique?
Adams detailing spray is great. I have been using it for years.
http://www.adamspolishes.com/c-11-de...less-wash.aspx
Application Technique
Fold a clean micro fibre towel into quarters and then spray the product liberally onto the surface of the towel, using very little downward pressure, gently wipe it off, then flip the towel and wipe again. When you see the towel start to show a line of dirt, flip it around and use a different section.
With it folded correctly you'll get a couple pairs of first wipe/second wipe sections out of it. But if you use a good amount of product you’ll get the towel pretty damp rather quickly. It usually takes 4 or 5 towels to wipe down an average vehicle.
WheelB
991 Turbo Vendor Classifieds
07-23-2018 09:37 PM
ECS Tuning - VW
09-03-2015 09:43 AM
Wheel Experts
09-02-2015 09:04 AM
Wheel Experts
Wheels/Tires
09-02-2015 09:02 AM
