Restoring exhaust tips and exhaust parts
What is the best product to retsore these tips?
I didn't install this Fabspeed exhaust, so I'm not sure what it looked like new, but it sure doesn't look shiny like on their website...can/should it be restored?
Tips
Exhaust
New Exhaust as shown on Fabspeed's website
Tips
Exhaust
Easy...if doing by hand, try P21S Polishing Soap first, then finish restorer to bring out the luster.
http://www.glisteningperfectionstore...21S/Categories
To bring out a shine like what you see in the picture, you'll to use a polisher and finish restorer.
Thanks Moe! I applied the P21S Polishing Soap and Finish Restorer with great results. I have only worked on the tips so far, and it was actually a lot of work. Scrubbing required lots of pressure, time, and patience. The results shown below took about an hour. I probably will not try to improve the rest of the exhaust system since you can't see it and the effort required is too high.
Can one remove the tips on a 997? I tried using the P21S Polishing Soap and Finish restorer this weekend, but found it difficult to use sufficient elbow grease given how close the top of the tips are to the bumper. If they could come off (easily) it would make it easier to clean.
Even cleaning them in situ made a big difference though.
Grab your socket wrench and 10mm socket (I think?) and good luck
From the muffler, exhaust is truly only a single pipe per side. It gets split out (if at all) by the tip. The bolt is on muffler side before Y and should be towards middle of vehicle. Here are some pix of what your tips look like off to help. Once you loosen bolt (no need to take all the way off), just grab the tips and wiggle back and forth to loosen clamp and pull off. Reverse to install but pay attention to make sure they are lined up evenly
Good cleaning
Good cleaning
Recieved my P21S Polishing Soap and finish restorer from Moe this week. Fast delivery as usual, I ordered it Sunday afternoon and it was waiting when I came home from work Tuesday.
Got around to attacking my exhaust tips today. Wow, after using these products they look like new. Very happy, didn't even take long, probably less than 30 minutes to do both sides.
I would post pics, but its raining here in Cali today. I guess you've all seen them before anyway.
joseph_number1
07-19-2018 05:45 PM
RS GT3 RS
09-24-2015 09:27 PM
