mink oil question
mink oil question
09 cayman base interior 12k on the car. i never cleaned the seats so they look like they are wearing but i guess i should try to clean it first. is mink oil okay or do i need something else. tanks
Take a look at this - it's worth the time and effort: http://www.detailedimage.com/Ask-a-P...r-care-how-to/
Something else I came across:
Mink oil:
On the other hand, mink oil is a valid conditioning oil. “Mink Oil” is a euphemistic name for liquefied pig fat and silicone. Like Lanolin, it’s very greasy and typically unsuitable for leather upholstery. Mink oil is most often used on heavy boots or other hard-working leathers.
Mink oil:
Leather Masters. Can get it from Phil @ Detailers Domain.
The liquefied fat from Mink oil is used mainly in the cosmetics industry (skin care) and is the main ingredient, along with silicone oil used for waterproofing, which negates transpiration (evaporation and hydration), which is necessary for the proper care of leather.
Neat’s-foot oil and Lanolin (Latin: lāna "wool", and oleum, "oil") has some major disadvantages - it softens uncoated leather very easily and can lead to the seating areas sagging, it is also susceptible to microbial attack, and can cause the leather stitching to rot.
Lanolin oil and the urethanes used as either a pigment or protective coating on automobile finished leather upholstery are not compatible as they will corrode the binder system, causing it to fail. When used on coated leather it will only sit on the surface and be transferred to clothing
"Using Oil-based Leather Care Products" - http://www.autopia.org/forum/guide-detailing/136820-using-oil-based-leather-care-products.html#post1450942
“Proper Finished Leather Cleaning and Care” - http://www.autopia.org/forum/autopia-detailing-wiki/136421-proper-finished-leather-cleaning-care.html
“Leather Surface Identification” - http://www.autopia.org/forum/guide-detailing/136895-leather-upholstery%3B-surface-identification.html#post1451654
feels like wear........i weigh under 200 lbs and wear clean clothes.....i guess off to the dealer
04-28-2022 12:38 AM
away
09-04-2015 12:30 PM
