Help! Ink Stain on Ivory Console
I've got what looks like a black ballpoint pen mark on the driver's side of the ivory console (about an inch long) of my Jaguar, and I can't get it off.
I can't be sure that the mark didn't come from a gel pen because I didn't cause it (car was at the dealer last week, so you can guess how it got there). But it's definitely too thin to be from a Sharpie.
The console appears to be plastic covered in a textured soft vinyl. So far, I tried to following:
I've seen suggestions about using the following products on the internet:
- Goo Gone
- Mr. Clean
- Mr. Clean Magic Eraser
- Armorall Interior Cleaner
- Blue Coral Interior Cleaner
- 3M Adhesive Remover
- Hide Stick
- Alcohol prep pad (70% isopropyl alcohol).
- WD40
- Hairspray
- Nail polish remover with acetone
- Windex
- Cooking spray.
Dang...you listed most of what I would have tried. There is a product called Spot-Shot, which is a stain remover that claims it will remove most anything inlcuding marker...on carpet. I am not certain how it would do on vinyl. I would have bet money on the 3M adhesive remover.
Good luck with it and let us know if you find a miracle cure.
If it is ink Acetone may be your best bet, but I am not sure what it will do to the vinyl. I would skip nailpolish remover and go right for pure acetone, nailpolish remover is likely to have other additives that are only going to make it more risky. Dampen a small section of a clean white cloth and slowly blot the stained section.
Obviously I would give the caveat of testing in an inconspicuous area before you go after the stain. I would also be careful not to oversaturate the material. Acetone works wonders when trying to clean glue and adhesives, and my have the unintended side effect of releasing the glue behind the vinyl and causing it to come loose if you soak through the material.
Don’t use solvents on vinyl, you’ll dry out the plastizers and may cause the material to delaminate
Most ink removal products are designed for removal of recent (within 48 hours) ink contamination. Ink marks older than 3-5 days may not respond or will only be lightened
With the above in mind try Leather Master™ Ink Remover this biodegradable formula is very easy to use (wax-like stick container) and works well for all types of ink as well as lipstick
pwdrhound
11
11-25-2015 02:18 AM
TOGWT
Detailing
09-29-2015 08:05 AM
