Polishing After Opti-Coat?
Peeps, so I had my detailer do a 2 step polish and Opti-coat on my new - yes new black XKR. That was 3 months ago. I now can already see the fine spiderweb scratches. Do the average person the car looks great. But when you've paid $1k and saw flawless paint under halogen lights etc and now you see fine scratches in what was supposed to eliminate the need for polishing AND to see them so soon it's very frustrating. I've only used microfiber towels etc.
This got me wondering if I bought into a gimmick and will still need to polish and wax the car every 3 months afterall!
1) I was told that the fine scratches are actually in the Opti-coat and not the paint yet. So my Opti-coat investment won't just be gone with a light polish. Is this true?
2) How should I go about getting back the glass finish I started with? Hand polish with something like Klasse?
Couple things...
Opti- Coat/ Guard is NOT a force field. It does not prevent things like scratches and swirl marks, and is not marketed to. It simply reduces the potential for marring.
A $1,000 detail with Opti- Coat should have included some instruction on how to properly maintain the finish. If you are seeing swirl marks in the finish within 3 months then something is wrong with your technique. Just because you're using microfiber towels and other top of the line products, does not mean your technique is correct.
If you need to polish the paint every 3 months then something is definitely wrong.
1. Its possible the scratches are in the Opti Coat and not the paint. But polishing the coating will remove some, if not all the Opti Coat. FYI, Opti- Guard is actually more concentrated than Opti- Coat, thus it provides a thicker layer.
2. I wouldn't use anything stronger than Poli- Seal
Can you describe how you are maintaining the car?
Who is washing it how?
Are you wiping the finish down after driving it? With what towel and what Quick detailer?
Perhaps the we can help you avoid this in the future. Opticoat is not a gimick and I personally have it on 1 vehicle and am going to be applying it to another in the near future.
Here's a major tip....
When washing the car... don't use too much soap, a proper concentration is paramount. Otherwise the acidity of the soap will eat away the layer of wax.
Second, dry the car with a leaf blower. Chamois and micro-fibers will cause swirls.
Drying a car with a leaf blower is a great idea. However, using a high quality microfiber towel properly will not scratch paint.
Another questions would be to find out what polishes, pads, and steps were done first to eliminate the swirls in the paint as part of the original detail. It might be possible, not 100%, that the original swirls may have been filled, not legitimately removed.
Your washing and wiping technique would be the next in line of diagnosis. What wash mitt are you using? How are you washing? How are you drying? etc. Someone mentioned you don't want to use too much soap as it's acidic...I don't agree with that statement. Soaps are not acidic and the soap actually suspends dirt particle so it can be rinsed off. So follow the label instructions on the soap bottle.
If that's the case then the Opti- Coat would fail as there can be no oils on the surface.
Everybody knows that....
I believe the statement I made was to follow manufacturer recommendation.
Who did you opti-coat?
I was just curious who did your opti-coat? I assume it was in Dallas? I'm in Dallas and looking for someone who knows what they're doing to do mine. Of course it sounds like yours may not have held up to well, would you recommend this detailer?
Thanks!
