Menzerna polish differences
Can anyone give a description of the differences between Menzerna Super Intensive Polish, Intensive Polish, PO106FF, and PO85RD? I can't quite figure out what the Pro's and Con's are of each.
ip and sip are have more cutting ability than 85rd and 106.
106 and 85rd are finishing polishes the last step before the wax or sealant.
For an enthusiast detailer IP will be fine either 106 or 85 would be great.
85rd was replaced by 106, alot of detailers love 85rd because it is said to have longer work time.
I personally like 85rd better but they should finish out about the same.
What color is your car?
Let me know if you need more help you can always call me up.
Rick,
Depending on how bad the swirls are I would trying going
106 with a green pad with the PC on speed 3-4.5. If that doesn't work I would try intensive polish with a green or yellow pad on speed 3/4.5.
(note: depending on what pads you are using you can go cut or med cut.)
I'm gonna say from what I've seen with many black cars you may have to start with IP then finish off with 106. Do you have any pictures?
ECS Tuning - VW
09-02-2015 01:19 PM
manfred@loma_wheels
09-02-2015 11:22 AM
