Filtration Systems
Filtration Systems
Anyone use a filitration system for washing their cars? I've been shopping for one at home depot and they have a lot of options. I'm ordering the foamgun from detailers domain and I'm concerned that I'll lose water pressure with the dual filters. Anyone have advice?
Get the CR Spotless system and call it a day. You'll wonder how you did without it. It's a true deionized water filtration system. You do a final rinse with the cr and either air dry or forced air dry using an airmax. The water dries spot free, or close to it.
Considering the CRSpotless refills are quite expensive, I'd like to know how much roughly the calculated cost is for each car wash use.
I've been using the Mister Clean Spotfree Autodry which works pretty decent, but the best thing is that the calculated cost is only 70cents per rinse.
But I'm still trying to justify buying the CRSpotless system...
If you get a TDS meter, you'll be able to calculate how many gallons each CR Spotless sytem can provide. The DIW-20 has a capacity of 0.33 cubic feet.
In my area, the water is excessively hard. Over 550 ppm on my meter. Use the formula 235,000/TDS (550) * 0.33 cubic feet of resin = 141 gallons. At a cost of about $90 per refill, each gallon of deionized water costs me about 65 cents. Average 3-4 gallons for a final rinse...you do the final math. Sure beats etched clear coat from hard water.
Costco sells the larger CR Spotless for $419.00 This includes a refil resin pack, 50 foot hose, with the cart ($449.00 for just the unit through CR).
I had the smaller unit and while it worked great, I like the convienience the roll-cart adds and not having to worry about changing filters as often with the DIC-20 as well. It is definately worth every penny.
Originally Posted by bbywu
Actually, it really depends on how hard your water is. A Autodry cartridge is about $5-7 dollars. How many gallons do you really think it can provide? The reason it lasts, is because on the final rinse, the nozzle is so small, that the flow is limited.
I got the CR spotless system as b-day present in june, cant beleive i hadnt purchased one sooner. I use it to wash and rinse, and end with no water spots whatsoever. My wife bought it from costco online as well, came with extra refill of resin, hoses, nozzles, tds meter. Great unit you cant go wrong with it.
dc
dc
COBB Tuning
03-29-2016 09:26 PM
COBB Tuning
09-09-2015 09:13 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
