Agency Power Ferrari Titanium Exhaust Systems
Agency Power Titanium Exhaust System Ferrari F360 99-04
Agency Powers Titanium Exhaust Systems are made of 100% lightweight titanium. Not only will this exhaust give you more power through the already amazing powerband, but because of the titanium construction, you will get a unique F1 race sound from your Ferrari. The exhaust weighs much less then the factory exhaust. This benefits your power to weight ratio, which makes your car that much quicker. Shaving weight is the number one way to increase your cars handling, off the line acceleration, and stopping distance.
Not only is the Agency Power titanium system light, but it greatly improves the exhaust flow and helps to prevents heat soak. The larger piping paired with the 1mm walls are the perfect combination for more power, a race car sound, and weight savings.
The system includes titanium tips, as shown.
Specifications:
60mm inner pipe diameter
76mm Tips
Weighs only 10lbs. Thats an incredible weight savings of 56.5lbs over the stock 66.5lb exhaust!
Agency Power Titanium Exhaust System Ferrari F430 04-09
The new Agency Power Titanium Exhaust Systems are made completely of ultra light titanium materals. The exhaust design will give you more horsepower through the already amazing powerband. Because of the titanium construction, the high recognized Ferrari sound will be that much intensified from the exhaust system. Titanium is a very expensive material and its use gives a substantial weight reduction in comparison to the stock exhaust. With the weight loss, you are saving lbs on the car which provides you a better power to weight ratio. Less weight, more horsepower is the perfect receipe for speed. Shaving weight will also improve your cars handling, off the line acceleration, and stopping distance.
The Agency Power titanium exhaust system is light as we discussed, but did you know that titanium does not retain heat like stainless? The larger piping paired with the 1mm walls are the perfect combination for more power, a race car sound, and weight savings.
Specifications:
60mm Piping Inner Diameter
76mm Tips
Weighs only 16lbs. Thats an incredible weight savings of 24.7lbs over the stock 40.7lb exhaust!
PLEASE CALL OR EMAIL JOSH FOR SPECIAL 6SPEED PRICING!
480.966.3040
X230
josh@vividracing.com
Specifications:
76mm Tips
Specifications:
76mm Tips
480.966.3040
X230
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
drinaldis
09-28-2015 01:37 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
