How to increase the ground clearance for 2008 F430
How much is it? Novitec crap is overpriced, is there any alternative? Something like what is available for GT3's?
roberuta.com/about/index.html
thing looks amazing, watch it work http://www.youtube.com/watch?v=8VgpkNnwIwg
now how can i get it and who knows how to install it
Unless I missed the point, I believe that Jwad's original question about vehicle ground clearance was that it would not be able to drive on to a KW lift. The road height might be fine, but some of the lifts that are available cannot accomodate low-ground clearance cars. I have seen where people have fabricated small ramps that allow the car to drive up onto some sturdy wooden boards (a couple of 2 x 12's bolted together) that run along side the lift pads and allow the car to clear the lift pads. Then the car can be raised using the lift. I borrowed a photo from a detailing web forum to illustrate.
The steel ramps to the sides of the lift are used for low-clearance cars to drive on to the boards that parallel the lift. FWIW
[If I did miss the point, then never mind!! ]
albert@velosdesignwerks
09-03-2015 11:11 PM
09-03-2015 04:56 PM
