New Garage with an attached House
#46
Well here's some follow-up information since I couldn't find the answers to this on boards anywhere. I called a local LiftMaster dealer and they recommended the JackShaft opener 3800. It can go on either side and be hard-wired in if desired. There is a backup battery and a remote light can be wired anywhere.
I can't recommend it yet, but it's the one I'm getting: http://www.liftmaster.com/consumerwe...lJackshaft.htm
The type of door which has tracks running right along the top of the ceiling is called a High-lift Door (duh ).
#49
I was in Germany for 12 days and when I got back it looked like this.
Might be hard to see, but that's hot and cold filtered, softened water hook-ups
My electrical sub-panel and on the lower-right a line to my 90 gal compressor in the basement and rough-in for central vac - central vac for the cars - YAY!
The high-ceiling for the lift
Little character sills for the other 2 stalls
#51
There is some kind of water-proof **** going up the walls to about 4 ft. I don't have drains anyways, so I probably won't wash inside, but maybe...I'm sure I'll have a reason to try it out at some point
#57
Some updates to the garages exterior. Also, worthless in the pictures, but the walls are all sanded now ready for primer and paint and the ceiling has had it's knock-down treatment.
#58
wow didnt even see this until now. Very nice. congrats!!! If you dont mind which area in Mpls are you. I work in real estate but cant pinpoint the area where your home is.
Either way, very impressive!!!!
#60
Hi Bif,
I'm local to you and have installed the liftmasters. Very nice. Make sure the garage tracks are angled to the ceiling so you have max headroom for a lift.
I to am interested in the heater. I'm all wired and piped for gas but need to find the right heater.
Cheers
Cheers
