Garage Floor Project
Hey,
I am going to undertake a garage floor project this fall. The pics here of garages are inspirational, to say the very least! You guys have obviously done a lot of homework!
Could someone lead me to some threads about tiles vs rubber like products I see in the pics throughout this forum. I live in a cold climate as well, car will be off the road for over five months... but will share garage space with the daily driver so moisture will be a factor (lots of ins and outs), salt from Canadian roads will also be in abundance in the adjoinig stall.
Thanks...
Thanks...
I am in the same situation as you are with the moisture. I have a 8' electric baseboard heater, as well as insulated the walls and ceiling. I just added a few 400 cfm bathroom fans that are controlled by a thermometer (hot days in the summer) and a humidistat. The system works very well, and seems to keep the moisture levels down.
I have done a few other things to my garage, including the floor (used epoxy - tiles make too much noise). I have also added a few (pre made) pieces of storage cabinets.
Good luck with your project.
project ready to go
I have decided to go with Porcelain tiles on the floor which will go down in a few weeks from now. First thing getting done is to repaint the walls, I will be moving the vac to the basement to free up the wall space. I am still trying to figure out what to do about cabinets....
i live in metro nyc area and after 3 yrs i just ripped out all the racedeck flooring from all 3 bays. There were small puddles of water underneath, mostly from power washing. My garage is used every day and racedeck isnt worth it. always looks filthy. For a spare garage to store toys, prob fine, but not for everyday. Back to square 1.
I have had the garage painted, added some posters and pics on the walls. The floor will go down next spring when I am satisfied with my research. Cabinets to follow not long after...
Hey 6speeders...
It's been a very long winter in Ontario and we are all ready for spring. After toying with the idea of once again doing my garage floor with epoxy, I have decided to do what I had already decided to do... LOL....do ceramic tiles.
The tiles will likely go down in the next five to six weeks once it warms up a bit and I will post pics during the process which should be valuable for anyone else considering ceramic tiles as an alternative garage floor covering.
The chandeliers will go up as the final touch!
I've finally started on the garage floor. After a lot of looking about I did decide to stick with porcelain tiles for the floor. Durability with ease of cleanup were really the deciding factor for me.
I went for 12x12 sizing, the dark areas on the floor were a material used to fill the joints and the odd crack here and there. There was a low area in one section that you can see which needed to be built up to redirect the angle for water flow during cleanup.
