eclou's garage project
#54
we've been really happy with the BMW. It's not the most athletic handling car, off from the spectacular E39 528 sport we had a decade ago, but for a limo-sized car it handles smaller than it is. Our 750 is the Msport and I plan on flashing the ecu to get to >500 hp via Dinan or Motorwerks. It's the wife's primary car but I have driven it on a couple trips to Dallas and have been impressed. Plus it is hard to beat BMW's lease deals on these cars
#55
Eugene -
Background - I have plans laid out for a 36x36 detached garage. I have tried to upload the .pdf's but I keep getting a failure. Below are google docs links - the best I can do at this time.
https://docs.google.com/viewer?a=v&p...ZWVjZjY3&hl=en
https://docs.google.com/viewer?a=v&p...ZTZmYmQy&hl=en
Questions:
1. How does the double width plus single width door work out? I originally had my "people" door on the front like yours, but I moved it to the side to allow the doors to be spaced a little further apart.
2. How did your permeable grass drive work? I would really like to use the same block/grass solution in front of my garage, but am worried about how it will hold up to daily traffic. I am under my ground coverage limits, but I would rather let more water into the ground if possible.
3. My design has a single post, in retrospect do you think it was worth the additional expense to have the floor completely unencumbered? I have some flexibility on the placement of the post, so I am going to nuzzle it up against the left hand post of the two post lift.
4. Other than making it bigger, anything you wish you had done differently?
Tal
PS - my brother has been cleared to go back to work on the 22nd of this month following his motorcycle accident - almost 6 months to the day. A pretty remarkable recovery from where he was in late March.
Questions:
Tal
#56
Tal, plan looks pretty good. The only thing I would question is the placement of the people door on the left elevation. It cuts into usable space for shelving parallel to the car. I would consider moving it to the rear elevation (actually your plans show a door there but not on the elevation) or to the front with the garage doors. 36' is plenty of room to get a 10' and 16' garage doors with a 40" wide pedestrian door. My elevation with all of the doors is actually only 35' wide!
The permeable pavers work very well. I roll my truck with trailer loaded with the race car over it all the time. There is no movement or unsettling. Plus at most viewing angles from the house, all you see is grass.
I would pony up the $$ for the clear floor and no post. I would do a dropped steel beam and then you will have a "free" chain hoist and trolley. It cost me an extra $5k over just engineered wood beams, and the overhead attic space area will hold that much more load for storage.
In terms of things I would change - maybe a foot wider since I would have gained more height in the attic and more space for my side workbench area.
I would also make sure your electrical has 220v circuits for 1)lift 2)air compressor 3)wall outlet for welder/etc. I would also have black iron piping installed in the walls for the air line drop points. This stuff is cheap to do now and can be hidden in-wall.
Glad to hear about your brother!
#57
I believe that Eurocharged does the flash for Motorwerks. They did my (former) C63 w/ good results.
