Garage lift
I just installed a Direct Lift 2 post from Greg Smith Equip (no affiliation) in my garage and I love it! Well made, USA made hydraulics and pretty sturdy.......and its BLACK! (happens to fit my color scheme in the garage). They say its a 9'3" but its a bit taller as I had to nibble some drywall and a hint of truss out from one area to make one side work (other side is within a vaulted ceiling area.)
bad camera pic and the garage isn't done so no crap from anyone
nibble a truss!!? from the looks of that (not the best picture) that would be a girder truss, read structural bearing point, hope you did not take a lot out of it or you could get a suprise garage addition.
Wow, thats close! Mine was to tall (as commented before). Luckily with the 16' door, my motor was offset so not an issue. I did however have the track raised to the 20" radius.....allows vehicles to just clear the track on the side. I'm about 3" from being able to have the car all the way up and the door open all the way. I have hurricane bracing in the way, I could cut it or adjust the door to not open as much but so far it hasn't been an issue.
What do you think of the lift? Not bad for the money.
I'm happy.
Yea, I think it was $1500 + shipping of $150 to get it to a depot. Then I had the professional installer www.liftguy.com pick it up, deliver and install it for about $400.
I'm happy.
I'm happy.
TIA,
Charlie
Garage rails
Hey guys-
I also want to install a lift (have 10 foot ceilings) How does raising the rails on the garage door tracks work? Is it complicated? How does the door come forward?
Please advise.
Paul
Please advise.
Paul
My ceiling is just shy of 10', and here's a pic with the Pantera on top, C4S below (as you can see plenty of room for the C4S). The track alteration was $400, installed, and was a replacment from the radius upward, including a new spring assembly. So as you see it in the pic, I can open the door and it clears the upper car easy.
Also better make sure your door opener is strong enough to lift the door now that it will travel up more than it did before and is "heavier" to the door
what brand door? Mine's a Clopay and I still keep in touch with the local supplier, so he provided the parts and labor to change everything out......ran about $500. I would check your door and then call the local dealer, see what they can do for you.
I'm about to buy this to put in my garage:
http://www.gregsmithequipment.com/At...atlas-nine.htm
Any recommendations away from this? I'm about to buy.
