***Laser Interceptor Laser Jammer Group Buy***
#31
#32
deputydog, I'm guessing there is but I thought I'd ask anyways. Is there any problem with sticking the heads behind a grill? Been wanting to place them on a 06 G35 but not quite sure where I can place them on the front.
#33
Anybody secure the heads with a foam double stick tape, like they use on some spoilers??
#34
Are you talking about the mobile speed cameras? I haven't seen any in San Diego.. In Phoenix they have cameras on the freeway, but they are not using laser or radar to capture your speed. They are using sensors in the ground to gauge your speed, thus any laser jamming would be useless.
Richard
#35
Deputy,
Just sent you a PM for a friend.
Thank you.
Thank you.
#36
#37
never used it before. please more info?? what to look for, and how to use it.
#38
It's made by 3M. Google VHB tape. Use it like normal double sided tape. Very strong (stronger than rivets). They build skyscrapers with it
#39
Regular Front and Rear Slim Sensor's dimensions are exactly the same in height and width and differ only in their depth front to back. This is to better facilitate installations under say the trunk lip of most vehicles. As the Slim Sensors have special optics designed to better address the characteristics of LIDAR Enforcement from the rear, the Regular Sensors should only be mounted up front and the Slim Sensors in the back of your install vehicle as the Regular Sensors perform better up front and the Slim Sensors perform better in the rear.
lim heads have a wider receive angle compared to normal heads. This also means that normal heads have a higher optical gain (meaning better reception) in the more limited angle they cover.
All in all:
Angled shots: slim heads
More coverage area: normal heads
Sunlight interference rejection: normal heads
Long distance shots: normal heads, doesn't really matter as receiving not the problem
#40
#41
Mine installed with tape and secured with zip ties. Works fine. You can actually use the zip ties to adjust the tension to level the heads if that makes sense.
#42
http://elvato.blip.tv/file/1701071/
http://www.youtube.com/watch?v=eHCT7D-0XIs
#44
All pm's received and you should have invoices in your email by morning. Pay tomorrow and you could be jamming laser by the weekend
#45
Thank you for the information deputydog95. That works out nicely. I would also like to add a personal thank you for doing this, and I think I speak for the other members here also, it is a really nice thing that you're doing by saving people money like this. You turn on the news these days and it's all so depressing, and with the recession the way it is, it's hard for most people to buy things such as this. It's really nice to see when someone like yourself does nice things like this to help people. Just a quick note to let you know that it is greatly appreciated. I will send you the information that you requested via PM either today or tomorrow. Thanks again
