VF Engineering Supercharger Group Buy!!!
VF Engineering has approved Vivid Racing to do a limited Group Buy on all their supercharger kits for the BMW M3 E46 and E36 models from now till October 31, 2009. To get this special discounted price, we MUST HAVE a total of 10 people signed up. This post will be put up across different forums so we will let people know once we reach 10. We need a $1000 deposit to commit you in the form of credit card or paypal to sales@vividracing.com.
VF Engineering Supercharger System BMW 3 Series E46 - Retail $5,000 Special $4500 Shipped. Read More Here - http://www.vividracing.com/catalog/turbo-supercharger-superchargers-c-4266_4424.html?class_9=1870&my_type_id=8&my_value= 28&class_8=28&filter_id=262
Stage 1 is setup to create 6psi manifold pressure at peak boost. VF engineers tested and found 6psi to be the optimal induction charge limit without aftercooling. Looking at the dyno results, despite max torque gains of about 50 ftlbs, there are peak torque gains of 70-80 ftlbs! The "delta" gains are more significant than max power gains.
GIAC custom tuned stage 1 software
RPM limiter increased
Soft rev limiters and top speed governor removed
Vortech V2 Super Quite SC trim polished supercharger
3 year unlimited mileage limited product warranty
VF- CNC machined 6061 aluminum bracket system
OEM BMW idler pullies
OEM High flow fuel injectors
VF- Custom molded polypropylene ducting
VF- Custom tuned supercharger intake
Bosch overrun bypass valve system
Custom crank case ventillation system
4 ply silicon couplers with OEM screw clamps
VF- CNC oil fittings with high pressure OEM oil lines
Replacement OEM serpentine belt
K&N induction filter with cold air intake and optional air box
Comprehensive installation CD Rom
Compatible with automatic transmission (pls specify)
Precision Made in California, USA
YouTube - Mike Benvo's Supercharged BMW 330ci vs Modded M3 Race 2
VF Engineering Supercharger System BMW M3 E46 - Retail $10,000 Special $9750 Shipped.
Read Here - http://www.vividracing.com/catalog/vf-engineering-stage-1-supercharger-system-60psi-bmw-e46-m3-0106-p-20043.html
Horsepower: 333 to 480 (Gain of 147 HP)
Torque: 262 to 330 (Gain of 68 ft/lbs)
Stage 1:
5.0-5.5 psi
chargecooler manifold system
OEM cooling system
Vortech V2SQ-SC trim
Type-R Bypass system
Stg1 fuel injectors
Stg1 GIAC ECU flash
400whp on 91 octane
YouTube - The VF-Engineering E46 M3 Supercharger
VF Engineering Supercharger System BMW 3-Series E36 - Retail $4500 Special $3995 Shipped.
Read more here -http://www.vividracing.com/catalog/turbo-supercharger-superchargers-c-4266_4424.html?class_9=1873&my_type_id=8&my_value= 28&class_8=28&filter_id=262
Horsepower: 189 to 297 (Gain of 108 HP)
Torque: 185 to 247 (Gain of 62 ft/lbs)
Specs:
- GIAC custom tuned stage 1 software
- RPM limiter increased to 7000 rpm
- Soft rev limiters and top speed governor removed
- Vortech V2 Super Quite SC trim polished supercharger
- 3 year unlimited mileage limited product warranty
- VF- CNC machined 6061 aluminum bracket system
- OEM BMW idler pullies
- OEM High flow fuel injectors
- VF- Custom molded polypropylene ducting
- VF- Custom tuned supercharger intake
- Bosch overrun bypass valve system
- Custom crank case ventilation system
- 4 ply silicon couplers with OEM screw clamps
- VF- CNC oil fittings with high pressure OEM oil lines
- Replacement OEM serpentine belt
- K&N induction filter with cold air intake
- Comprehensive installation CD-ROM
- Optional stage 2 kits in development for certain models
- Precision Made in California, USA
VF Engineering Supercharger System BMW M3 E36 - Retail $4500 Special $3995 Shipped.
Read more here - http://www.vividracing.com/catalog/vf-engineering-stage-1-supercharger-system-6psi-bmw-e36-m3-32l-9699-p-20035.html
Horsepower: 240 to 350 (Gain of 110 HP)
Torque: 236 to 295 (Gain of 59 ft/lbs)
Specs:
- VF- Customer tuned supercharger intake
- K&N induction filter with cold air intake and optional air box
- Compatible with automatic transmission (please specify)
YouTube - VF-Engineering Supercharged BMW E36 M3 on Dyno
Contact your Vivid Racing Sales Rep to Sign Up. WE MUST HAVE 10 People.
Stage 1:
5.0-5.5 psi
OEM cooling system
Stg1 fuel injectors
Stg1 GIAC ECU flash
400whp on 91 octane
Specs:
Specs:
