Brembo Brake Blowout - Stop Faster!
Dropping a special on the new Brembo GT 6 piston front brake kit and 4 piston rear Kit for all Porsche models. Special is for:
996 C2/C4/C4S 99-04
996TT 01-05
997 05+
Front kit -So low in price makes vendors cry.
Rear kit - You will want this!
Each kit comes with 2 piece Rotors, Calipers, Pads, Steel Braided Brake Lines, and Hardware. Calipers available in Red, Black, Silver, and rotors in drilled or slotted.
Benefits of the Gran Turismo Brake System:
The Gran Turismo system's level of technology and performance is unrivaled by any other product on the market. Each system is designed vehicle specific for maximum performane and "Optimum Brake Balance". Gran Turismo Systems are comprised of lightweight 4, 6 or 8 piston calipers and 1 piece or 2 piece "floating" vented rotors up to 15" in diameter. Calipers are available in red, silver or black and discs are available in cross drilled or slotted. Increased brake torque and thermal capacity, dramatically improves the vehicles performance. This powerful combination offers the extreme in Brembo's leading edge technology for high performance street and track use applications. Brembo brake systems are fully compatible with your vehicles ABS and traction control systems. Systems are pre-assembled and include all necessary hardware for ease of installation.
Proven on-track performance; Disperses gasses, cleans pads for better ?bite?; Reduces ?usprung weight? for better handling; Provides maximum braking force without the flex of sliding callipers; Reduces heat-related stress, increases brake performance and pedal feel; Aggressive pads that last longer and provide the highest level of performance.
We also carry other OEM replacement parts. Pads, Rotors, Lines, and more.
Contact us for any braking needs!
996 C2/C4/C4S 99-04
996TT 01-05
997 05+
Chasen,
the 6piston may.. Brembo is emailing me the drawing to put on the back of the wheel to check. I will put it up to my stock wheels to let you know. They say 19's definitely. Will let you know!
Is the sale still going on? If so can you pm pricing for the cross drilled 15 inch 6 piston mono block in red? Thanks!
Can you send me an email to dan@vividracing.com so I can email you a quote from our system. I need to know, year, make, and model, rotor size you want (355 or 380), and which color calipers. Thanks!
Dan
Dan
send me an email to dan@vividracing.com with your name, car info, rotor style, and caliper color!
dan
dan
Here is a little update from our initial install of the Brembos!
http://www.myvividracing.com/showthread.php?t=20896
