Help, need part for 996 GT3 RS dampers
Hi,
I am removing my KW coilovers and going back to the original dampers, but it seems I am missing a part to fasten the rear dampers....
The part is screwed on to the rear damper and according to Porsche is not sold separately.... Meening I would have to buy a whole new damper for the rear....
The KW damper has a different system which is welded to the damper and can not be used.
Anyone knows what part I am talking about ? And if it is possible to get hold of from the manufacturer of the original damper ?
Jo
Jo
996-343-041-97 (2) shock absorber996-343-531-97-504 (1) coil spring set996-343-070-93 (2) swaybar droplink996-347-804-90 (1) steering wheel (red)996-347-804-91 (1) steering wheel (blue)996-331-111-90 (1) rear wheel carrier (L)996-331-112-90 (1) rear wheel carrier (R)996-341-661-90 (2) cover999-217-042-09 (12) hex-head bolt M8 x 35996-341-121-90 (1) control arm (L)996-341-122-90 (1) control arm (R)900-076-025-02 (2) hex nut M8999-025-269-02 (2) washer 8.5 x 17 x 6996-341-441-90 (2) bearing flange control arm996-331-551-90 (1) support996-331-051-92 (1) rear axle side section bracket (L)996-331-052-92 (1) rear axle side section bracket (R)996-333-051-97 (2) shock absorber
I believe you are looking for 996-333-051-97.
tropicatango
10-14-2015 11:32 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
PelicanParts.com
996 Vendor Classifieds
08-18-2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-18-2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
