Any CGT owners who have owned a Murcielago??
Guys,
Adding a CGT to the collection. I am wondering - how does the ground clearance of the CGT (which of course does not have a lift system) - compare to the stock Murcielago (on regular setting - not raised)?
I just want to guess - in advance - where I can go and where I can't - based on my experience with the Murcie.
Thanks in advance!
Thanks in advance!
Guys,
Thanks in advance!
Thanks in advance!
I sold the Murci Roadster but it will be hard to get used to not having the lift system. I would say they are about the same height, you will need to remember that the lift system is not there as you are driving the CGT.
Also REMEMBER its a two wheel drive not an all wheel drive. They will spin out, especially if the tires are cold.
Good Luck and Congrats!
DM1,
Please also remind me - does the CGT have some sort of rubbing strip on the underside of the front splitter to take the abuse from the road - for those times when you do get caught on a ramp - or is it like the Murcie - where you start the scrape the paint if you get it wrong!
OH and by the way ......I also got the fastest color!!...........Guards Red!
DM1,
It has a small 1" rubbing strip on the underside for the front splitter. ..
You'll love it!
Lambo is gone! It was replaced by a Ferrari.
It's a Bendpak. I need to extend the ramps with some boards to put the CGT on it.
I got the narrow one because I would loose a spot in the garage.... (see picture of garage) The only problem is the Lambo didn't fit on top. I would park it under the lift.
Is it a "Benpack" or a Bend-Pak? I can't fnd anything on the internet as per your description.
10-06-2015 03:43 PM
