Is this the infamous RMS leak?
Yep--- that's no reason to worry, it may just seep a bit, and not get worse. I think part of the problem is the 0W/40 oil is so thin, it's almost impossible not to have some leakage. To me, the process of removing the engine, with all the things that have to be disconnected (a/c freon lines, coolant hoses, oil lines, electrical connections, power steering lines, etc) the opportunity to create a new problem from all that work far outweighs the little bit of oil that leaks. I'd rather not have a mechanic, no matter how good, messing with everything required to remove the engine if not absolutely necessary. As they say, "the devil you know is better than the devil you don't know."
