GMG MOTON instalation
I am going to start the installation of the GMG Moton WC suspension.
I made some canister brackets for the roll bar and still finding a nice solution for the fronts etc great project I think.
I have a question, today I looked at the upper part of the front shocks and didnt find the little cable that normally is connected to the shocks for the PASM to make the suspension hard.Why I don't have the front shocks with the cable if my car has the PASM button in the dash?
I also need a suspension geometry set up...I hope someone can help me.
First, congratulations on getting the Moton's! I have no idea about the cable for the front shock! I haven't looked for it on mine.
On the setting up quistion, I'm sure that GMG would help you with a base set-up that they recommend. You'd have to do slight adjustments later when you drive it though to suit your driving style.
I would assume that GMG will take care of everything for you on the install.
Then you adjust to your likings and style of driving.
I would follow all of GMG's recommendations. God knows they know what they are doing.
GT3Ranger
GT3Ranger
It does but the Moton replacements do not. So if you bought a replacement Moton/GMG setup then the Sport button would not work.
from my understanding Moton is pretty good with support as they actually took my car out to the track when setting up my gallardo. they spent the entire day setting it up finding the correct spring rate camber and tow settings. they even did a custom front end lift unit that they adapted off my stock setup, so i can still have the front end lift. great company.
This is the second day of installation and the real challenge for me is to install all the new components with out doing any permanent mod in case I want to have a 100% OEM car some day.
I need some help from you guys,please the a look at the way I think the front and rear shocks have to be ensembled and correct me if I am wrong.I will also install rear thrust arms,dog bones and some other components will post more pics in the next days.
Where can I find the way to eliminate PASM?
