KW Hydraulic Lift System
Are the KW coilovers PASM compatible?
Here is the official US Prices for the KW HLS (Hydraulic Lift System)
Carrera GT
With KW Coilovers - All 4 Corners
Front Only HLS - $21995
Front & Rear HLS - $23875
For Stock Suspension
Front Only HLS - $9150
Front & Rear HLS - $10875
GT3 / GT3 RS
With KW Variant 3 Coilovers
Front Only HLS $8750
Front & Rear HLS $10200
Front Only HLS $5375
Front & Rear HLS $6950
Let us know if there are any questions. We work closely with KW as one of their largest stocking dealers
Carrera GT
GT3 / GT3 RS
What about pricing for the 911 turbo?
And would it be possible to use the Hydraulic lift with aftermarket coil-overs from someone else?
The spring rates should remain the same on linear springs but should be slightly increased on progressive springs (waiting for confirmation)
Absolutely, there is a kit for vehicles already equipped with KW coilovers
996 applications are not available yet.
997 Turbo
KW Coilovers with HLS Kit
HLS Front $8975
HLS 4 Wheel $10425
Equipped with KW already
HLS Front $5650
HLS 4 Wheel $7250
There is only OEM applications for 997 GT3/RS & Carrera GT currently
If the dimensions are the same as KW or OEM then the HLS kit would work. We have a kit on order already for the 997 GT3/RS so we can measure & compare once the kit arrives.
I just ordered a 4 corner HLS system from Sam at Auto Talent. I am adapting it to JRZ 3 way race shocks on my 1badgt2 project. Sam has been VERY helpful with the technical data. I will let everyone know how it works once we receive the kit.
How would the KW shocks compare to the stock shocks on the Carrera GT? Are the prices quoted installed or just for the parts? If just for the parts, how much labor is required to install the system on all four corners of the CGT.
Thanks!
Thanks!
I will not find a reason to put this on my car.
