PETSHRK Project begins !! ;)
#69
I had a horrible experience too.....will never use them again. They didn't properly fix a wheel, paint chipped, lost an irreplaceable center cap.....
#70
untill you turn on the car. the light travels through the paint. you need to add a white bulb or do not slide the bulb in the parking light area, tape it behind the entire marker so you do not have to remove the bulb and set off some broken light codes.
