PCM retrofit - problem
yup.. thats where i went. the guys at Fletcher Jones now believes that the PCM is not programable. if the PCM came from a Bose system, then its configured as a digital audio output. unfortunately, my GT3 came with the ASK system (analog) and now my PCM is not compatiable nor progamable.
hey daytona.. remember i had a thread about getting the pcm installed. if i do not have the sound package plus will it work? it seems to have worked quite well for another member.. bsavino. are you sure there is no way around this?
the one that works for the BOSE amp is part# 997.642.143.xx. this one has no internal amp/drivers, so it has to hooked up with the external BOSE amp.
the one which you need is the same one i need, which has the internal amp/drivers which is part # 997.642.141.xx. i believe thats what porsche uses for GT3's with or without sound package plus.
the other option is to get the BOSE amp installed and the harness. i've heard mix information regarding the price of the oem BOSE harness. the other alternative is to just find the 997.642.141.xx pcm so you can use the internal amp.
hope that helps
well there are 2 kinds of PCM's, one for the BOSE amp and one for the ASK (extended package plus).
hope that helps
hope that helps
i actually got my PCM and Navigation Module from a 2 week old Cayman S. thats the one im trying to sell now.
Studio RSR
BMW //M
11-10-2015 07:08 PM
Studio RSR
BMW Vendor Classifieds
11-10-2015 07:07 PM
Studio RSR
Audi Vendor Classifieds
11-10-2015 07:05 PM
30, 6speedonline, 997, amp, bose, gtr, harness, ii, navigation, pcm, porsche, retrofit, retrofitted, retrofitting, sound, system
