GT3 harness/seat belt question
I'm trying to install a 6pt harness on my GT3/CGT seats. I want to keep my factory seat belts too. They mount to the same point on the seat. Is there a different bolt piece I can use to make them both fit? Thanks.
Don't know if it is the same on the new GT3/CGT seats, but on the previous GT3 seats, the harness(lap belts) mount on to the seat itself, while the OEM 3 pt. belts mount to the body of the car. You can loop the OEM belt through the shoulder belt guide and out the lap belt loop, then you will be able to use both...
Show us a pic of the seat and where the belts attach and maybe we can help. Chasen1211 is correct that on the GT3 seats they have anchors on the seat that the harness lap belt attached to the 3 point seat stays on the OE anchors. So you can use both. If you do not have the harnesses that are custom made for those seats a place like CDOC or Rennline sells adapter brackets to make it work.
