GT3 RS Clubsport Roll Bar Installation
I was helping a friend on the weekend install a Porsche GT3 RS Clubsport roll bar in his US spec 2007 GT3 RS (#2373) (Full photos and installation details to follow). As it is an early production RS it has roll bar stud plates factory welded to the floor behind the seats where the front base of the roll bar attaches, bosses welded to the floor under the seats to screw in eye hooks for sub belt attachment and even stud plates welded to the floor in each of the foot wells to bolt a front roll bar extension. Installation of the Euro/ROW Clubsport roll bar itself was straight forward however we spent considerable time measuring and cutting the rear shelf carpeting and undercushioning so the bar could pass through where it bolts to the rear shock towers (see attached picture). The carpet undercushioning is difficult to cut with any precision as it consists of thick, spongy foam (up to 3" thick) and some rigid styrofoam. It occured to me that a better solution would be to order a replacement carpeted shelf piece for a ROW spec 997 GT3 RS that came with the factory Clubsport option as it should have the proper bar pass through holes already pre-cut in the carpet and foam backing? Attached is a picture of the underside of the carpeted panel from #2373 which shows a 997.551.033.00 part number. Do any 6speeders have a ROW spec RS that came factory equipped with the Clubsport option? I would appreciate the part number of the carpeted shelf panel (and pictures of the carpet cutouts if possible)? Many thanks!
Khalid, thank you, I am interested in seeing the cutouts from both the top (carpet side) and underneath (foam side) the panel. I would also appreciate if you are able to get a part # from the piece.
Ed, we went to some extra lengths to minimize the risk of creaking / squeaking such as torquing every bolt on the roll bar to the same spec and at the front and rear anchor points. We also applied some anti-friction material under the front mounting points where they meet the floor plates. We did a spirited "road test" following the installation including some off-camber and it was dead solid. It might loosen up over time however so far not a peep.
I believe the part no for the carpet with holes is 997.551.033.90.A10 (black) . . . but perhaps someone here can confirm.
You might be right, I received a posting earlier with the same part # you provided so I called the guys at Suncoast Porsche (Ric) who checked the PET and he thinks its the carpet panel with the pre-cut holes for the Clubsport roll bar tube pass through. I ordered one and was told they will have it before the end of the week. I'm hoping its the right one. Thanks for your help! I'll post an update.
Found!
Suncoast (Ric) sent me this picture of 997.551.033.90.A10, its a winner! If you are planning a Clubsport roll bar installation you need this replacment shelf, it will save you lots of time and grief. Thanks also to Zellamsee for his lead on the part #.
Nothing wrong with a roll bar in a C2 so long as it's for track service! The RS carpet shelf is not compatible with the DAS bar. Although both the DAS and Porsche Clubsport bars use the shock towers as their rear mounting points the Porsche bar has a single bar pass through on the right side and an intersecting bar on the drivers side as indicated by the elongated cutout. I'd check with DAS, maybe they can provide you a cutout template?
Excellent idea! I am hesitant about putting a bar in that is going to make the view through the window "untidy". This car is still going to be my primary DD even though I have been driving my Audi more lately given the torrential rains we have had in NC lately.
Question -- the replacement shelf piece solves the problem of cutting through the OEM carpet at this level -- but, did you still have to cut holes at the bottom of the carpet (at the floor of the car, above the factory welded plates)? If so, is there a WW (i.e., non-US) part number for the rear carpet (with pre-cut holes)?
