How to tie car down on trailer?
Old 05-13-2009 | 02:18 PM
RMcG's Avatar
RMcG is a glorious beacon of lightRMcG is a glorious beacon of lightRMcG is a glorious beacon of lightRMcG is a glorious beacon of lightRMcG is a glorious beacon of lightRMcG is a glorious beacon of light
I have done this periodically with my RS for long trips, and inevitably it seems to lead to a wheel alignment when I get back from the trip, which is not good. I tie the car down by the wheels..(see below). Does anyone know if there is any alternative?
Old 05-13-2009 | 02:23 PM
HardCore Nice's Avatar
HardCore Nice is infamous around these parts
I seem to remember there being a product either from Dasport or Renntech for body tow-hooks. Someone attached them to a GT3 about 4 months ago.
Whenever I trailer my Carrera I use wheel webs that strap down the whole wheel instead of just strapping a single point as seen in the pix. That very well could be ur reason for alignments every time.
Old 05-13-2009 | 03:37 PM
NorthVan's Avatar
I have Rennline tie downs for my 997C2S, they work really well. I leave them on when on the track.
In the Front
http://www.rennline.com/Front-Tie-Do...oductinfo/E32/
In the Back
http://www.rennline.com/Tow-Hooks-an...oductinfo/E04/
Old 05-13-2009 | 03:45 PM
mousecatcher's Avatar
mousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nice
e-track is the best system. Like http://www.macscustomtiedowns.com/product/214/WheelNets but instead of fixed tie-down rings use e-track.
Old 05-13-2009 | 03:48 PM
NorthVan's Avatar
Here is a picture of them on the car (on the track), the are not in the way at all.
Here is another shot that shows the front tie down.
It seems like we have the same taste in stickers, yours on the back, mine on my window.
Old 05-13-2009 | 04:48 PM
AllanJ's Avatar
AllanJ is a jewel in the roughAllanJ is a jewel in the roughAllanJ is a jewel in the rough
Hmmm....crossing your rear wheel straps like that is probably putting lots of strain on your rear toe settings. Try strapping them straight back. If you want to cross your straps then try those rear brackets Rennline sells.
Good luck!
Old 05-13-2009 | 05:31 PM
NorthVan's Avatar
Good point AllanJ, but the tie downs work very well.
Old 05-13-2009 | 06:58 PM
TRAKCAR's Avatar
TRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of lightTRAKCAR is a glorious beacon of light
I have the same works perfect!
Old 05-13-2009 | 07:45 PM
RMcG's Avatar
Thanks to everyone for all of the help...(as for the stickers, I put them on every car I drive at the Ring.......
Old 05-13-2009 | 08:46 PM
NorthVan's Avatar
I saw your post last year about your transporting the car to Germany. I wasn't so lucky, I had to settle for renting an 08 Cayman S and driving the ring with that...what a thrill.
Old 05-13-2009 | 10:06 PM
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
The way you have tied on will pull out of alignment. I prefer a method I use either on trailer or in truck.
I use 4 primary straps -- they are good quality webbing ,approx 25mm (1") wide . Thru the wheels spokes and directly back & forward. Do not over ratchet-- firm is adequete .It is better still if you can use Cup type wheel hooks.
This stops car moving fore & aft --and sideways(it would have to make tighter to move)
None of this stops tieing down in other places eg toe hooks.
Old 05-14-2009 | 12:38 PM
adam89911's Avatar
adam89911 is infamous around these parts
Tie Down a car
Does anyone know how Porsche ties down the cars when they are being shipped from the factory in trucks?
Old 05-16-2009 | 07:57 PM
rasi54's Avatar
rasi54 is infamous around these parts
Cross tying wheels is a bad idea as it will create positive camber. If you choose this method pull straight and never run the straps around the tierod ends. I usually fabricate hooks on the chassis and pull at a small angle that way.
Old 05-16-2009 | 08:09 PM
fortyounce's Avatar
fortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of light
i just ordered a set of the 996 tie downs. i thought you might be interested in them as well.
http://www.autometricsmotorsports.co.../996/index.htm
Old 05-18-2009 | 09:49 PM
ast78's Avatar
ast78 is infamous around these parts
Do you have any close up pics of the rear tie downs and where you bolted them in?
thanks in advance
