Michelin PS2 or Cup Sports on a GT3?
you will wear PS2's much more quickly on track depending on how agressive your alignment is...driving cup tires on the street may affect the heat cycles and they will wear much more quickly than ps-2's on track or street...unless your alignment is more agressive than stock you probably will not benefit much from cup tires...even with more agressive alignment it depends on your level of experience...you may or may not benefit from cup tires and the quicker wear will be a disadvantage...if you are driving to the track and may encounter wet conditions you will wish you were on PS2's...
PS2 for the rain and Sport Cup for dry conditions, meaning another set of track wheels... or Pirelli Corsa System: better in the rain than PS2, as good as Sport Cup on dry conditions and no need for other wheels !
Personally, I track my GT3 most of my mileage so I use one set of wheels for rain with Pirelli Wet Slicks, another one for dry conditions with Michelin Slicks and the OEM wheels with Pirelli Corsa System for changing weather and the street. Perfect combination... if you have a trailer !
cnebrask
10-03-2024 08:19 PM
pshep138
09-01-2015 09:45 AM
Sterlingc1975
08-22-2015 02:30 PM
