Would you buy this car
I have found a car that I am considering purchasing....the following recall was done, but it is fixed now. Is this a rear main seal fix? Is it OK to buy a car with this fix done once?
Printable View 00004330105 Crankcase 12.03
Labor Operation Labor Description Time Units
10011906 Engine removed+reinstd 780
10012950 Engine cleaned 50
34352753 Transmission unflanged+flangd 90
VIN WP0AC29967S792307
Model/Type 997 810
Order Reference 2240824
Order Type CUSTMR Customer Order Damage Code 1359 050 000 2
Part Number Part Description Quantity
00004330105 Sealing ring f 11.22
99710126490 Sealing ring f 14.18
99710226491 Sealing ring f 34.14
13591959 Sealing ring f cranks. flywh re moved+rei 140
30010700 Bleed Clutch 50
30560150 Clutch disk checked 10
34352950 Transmission cleaned 30
44950300 Check front and rear alignment 80
44951550 Vehicle, front + rear adjusted 80
45601550 Steering-angle sensor adjusted 20
87031700 A/C EVACUATE & RECHARGE 110
Model/Type 997 810
PorscheEnthusiast
11-13-2015 02:23 PM
