need front rotor replacement. anyone tried girodisc?
You dont want to machine down the lip because usually its an indicator that you need to replace the rotors.
Worn rotors can create very serious braking issues, so you definitely want to monitor your rotor wear and pad wear. I've experienced what happens when you have worn rotors and fresh pads and it isn't fun.
I prefer slotted to drilled because I feel they last longer.
Yep, understand... my real question was the max lip thickness before the rotors need to be replaced. At the moment my rotor lip thickness is less than 1mm.
yup get it from alex. my set should be in either today or tomorrow.
Me too... just need to kill my front rotors first at Thunderhill. Talked with Mike the other day, he maybe going to Thunderhill too. How about you?
I will be at TH if it does not kill me to drive to Laguna one day and TH the next
lol ... show us your Brembo on your CSL
perhaps i can join you guys.. i'll ask ///M kevin as well
i have no CSL
Tell Kevin I will instruct him if he come out to the track. I can guarantee my instruction will make him slower than Joe lol
Go for it... you being tired will give me a shot and staying ahead on the track
You will love TH - it's so much safer than Infineon. I am sure you will be plenty fast in no time. I usually run the mixed group with trackmaster because I am faster at TH. I switch from mixed to your group at Infineon in the afternoon because I did not want the pressure to drive fast. The damn track was just way too cold ... esp after seeing that black 6 GT3 crash at turn 7
lol, maybe I can stop by Sharkwerks on the way back from Laguna for some much needed RS kool aid before heading up to TH the next day.
