Would like advise on single point to lift rear and front of GT3?
Is there a safe single jacking point on the rear and front of these cars? I would like to be able to put jack stands at the factory lift points on either end instead of one side at a time.
Yup, my method as well. Must be time to go home... description makes sense now but didn't hit me right the 1st read through. Still OP seems to be looking for a way to lift both fronts at the same time... I'm unaware of a way to do it without damaging the car. For the purposes of putting the car on stands it would be nice to lift one end at a time instead of one side at a time.
You can jack the rear from a single point, but I'm not aware of a way to do the front. I can't describe the rear location clearly without looking at it, but any Porsche tech can point it out. It is not an officially recommended procedure, which they will also point out, but I've never heard of a problem, when done correctly.
PenguiN
09-15-2015 11:44 AM
