Notices
RS Wing+Motorsport goodies....
Old 02-25-2010, 07:21 AM
On Pole's Avatar
On Pole is a jewel in the roughOn Pole is a jewel in the roughOn Pole is a jewel in the rough
This is a 3rd gear run up hill with the R&P.
http://www.youtube.com/watch?v=VQ25odOnl9s
Old 02-25-2010, 07:24 AM
Piero's Avatar
Piero is a glorious beacon of lightPiero is a glorious beacon of lightPiero is a glorious beacon of lightPiero is a glorious beacon of lightPiero is a glorious beacon of lightPiero is a glorious beacon of light
Strange to see that it does not seem to go as fast as mine??...
You have 8.32 gear ratio ?
I was in 3rd gear too in my video....
You're about 5 secondes, i'm about 4 secondes to hit the 8000 rpm..???
http://www.youtube.com/watch?v=iSnszu6FGMQ
Old 02-25-2010, 07:45 AM
On Pole's Avatar
I'm going uphill and starting out at lower RPM.
Old 02-25-2010, 08:00 AM
Piero's Avatar
Sure it's difficult to compare as it depends on several parameters.....
Old 02-27-2010, 10:11 PM
unique's Avatar
unique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud ofunique has much to be proud of
i heard that the 8.32 gear ratio can cause damage to the tranny, i am not sure about the detail of what the damage is. maybe you guys can elaborate
Old 02-28-2010, 03:02 AM
Piero's Avatar
It needs to be mounted via a Porsche specialist.
Mine is a Poarche mecanican and dealer for more than 30 years, and he knows what he does. he's an impressiv mecanician and tuning 997 GT3 cup is something usual...
Old 02-28-2010, 05:42 AM
Harold's Avatar
Harold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud of
Could you give me a rough idea of costing on this mod? My gearbox will be coming out this weekend on my 997.1 GT3 RS and would love to get more use out of the gearbox as I never need 6th out of my track. Having said that, I do go need to go up to 285kmh on the freeway drive to my track in order to keep up with my convoy and want to make sure I can still hit that speed.... anything above that I dont really need...
Old 02-28-2010, 05:55 AM
Piero's Avatar
Cost will be around 3000/3500$ all included.
8*32 ratio allows you to hit 282 km/h chrono, not more. (around 300km/h on the dashboard)
I think it's perfect for a track use...
Old 02-28-2010, 06:01 AM
Piero's Avatar
Here is an example of using 8*32 gear ratio on the road, with a cool driving....
http://www.youtube.com/watch?v=ffZpmmmsXAw
Old 02-28-2010, 04:47 PM
Harold's Avatar
Piero thanks very much for the info.... this is about all that I need.
Do you happen to know what is the difference between the cup car final drive and the motorsport items that you installed or are they acyually the same thing? Apologies for the ignorance, but my mech is suggesting this to me.
Old 03-01-2010, 12:07 AM
Piero's Avatar
The motorsport gear ratio part IS the final cup car item.
The difference between a cup car and ours, is that in a cup car getrag, each gear box pinion is in a specail material and cost 2000$ each!
But the ratio and the final drive is a motorsport part, so it's used in european carrera cup. (don't know for US championship)
It's the same for Pagid (green color) P50 brake pads, i buy them from Porsche motorsport, so it's the brake pads used by 997 cup in Europe.
Old 03-03-2010, 01:02 AM
Piero's Avatar
New pics as promised....
love how it looks!!
Old 03-03-2010, 02:43 PM
On Pole's Avatar
Here is my car.
R&P
Cargraphic Kit 3 exhaust
FVD ECU Software
Remove and replace 3.44:1 (31:9) stock ring and pinion with 4.00:1 (32:8) ring and pinion.
Replacing the ring and pinion of the GT3 transaxle with a 4:1 ratio unit retains the original gears and will not result in abnormal noise. Net effects are remarkably similar to changing and replacing transmission shaft gears with highly regarded reliability. WEe use the Porsche Motorsports 996 RSR ring and pinion set for best quality.
Gear MPH
6 172.6
5 147.9
4 122
3 94.8
2 68.5
1 38.7
Haku
04-05-2013 10:35 AM
Eric (Plug Guy)
04-26-2008 05:41 PM
icemann633
06-02-2007 10:42 PM
John Romano
01-06-2007 09:19 AM
Quick Reply: RS Wing+Motorsport goodies....
