Notices
Ruf RGT-8...live from Geneva!
Old 03-07-2010, 06:35 AM
scv8's Avatar
scv8 is infamous around these parts
Wow, that is beautiful. What is that part in the valley under the intake manifold?
  #32
Old 03-07-2010, 06:50 AM
ztnedman1's Avatar
ztnedman1 is a splendid one to beholdztnedman1 is a splendid one to beholdztnedman1 is a splendid one to beholdztnedman1 is a splendid one to beholdztnedman1 is a splendid one to beholdztnedman1 is a splendid one to beholdztnedman1 is a splendid one to behold
Originally Posted by Bigrigger
"The crankshaft is a 180-degree flat-plane design for optimal flow characteristics"
What do they mean by this?
Lets the engine rev higher and make more horsepower, but at the cost of torque and vibration.
Ferraris v8's are 180 degree flat plane cranks. So expect this Porsche to sound similar.
  #33
Old 03-07-2010, 07:20 AM
pfan12000's Avatar
pfan12000 is infamous around these partspfan12000 is infamous around these parts
Strange designation of 180 deg flatplane V8 confuses me. 180 deg V8 is a flat8 or boxer8. That layout of the cylinders ensures a low center of gravity for the crankshaft (heaviest piece of the engine), hence the 911 boxer6 is a 180 deg V6. The photos show a V8 but their designation of 180 deg is for the "flatplane"? Anyone knows what the designation used means?
  #34
Old 03-07-2010, 11:29 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
http://www.autozine.org/technical_sc...ne/smooth4.htm
However, the disadvantage of cross-plane V8s is also about the counter weights - not only increase the weight of engine, they also contribute to rotational inertia, thus making the engine less responsive and less revvy, dropping upper rev limit and top-end power. Moreover, the larger counter weights usually requires a larger crankcase to house them, thus raising the height (and more important, center of gravity) of the enigne. Therefore Ferrari all V8 models, TVR Cerbera AJP V8 and Lotus Esprit V8 employ flat-plane V8s instead.
Flat-plane V8 is named according to the shape of the crankshaft, which is in a flat plane. It is very much like two inline-4 engines mated together. In particular, it achieves end-to-end balance because the first piston and last piston of a bank is exactly in the same position, so are the center two pistons. This is just the same as straight-four engines, therefore the sound of flat-plane V8 is usually somewhat like a pair of four-pot engines screaming simultaneously, unlike the rumble-bumble of cross-plane V8s.
As both banks run like an inline-4 engine, there is second-order vibration. For a 90° flat-plane V8, the sum of second-order force generated in the 2 banks is - by simple vector analysis - 1.41 times (root-2) of the force generated by each of the inline-4 it consists of. And the direction of vibration is left-right instead of top-down. In other words, while displacement increases 100% compare with the inline-4, the second-order vibration increases just 41%. That makes the flat-plane V8 more refined than an inline-4 although it is not as smooth and quiet as cross-plane V8.
To exotic sports cars, less refinement is not a big problem. Especially they usually employ short stroke and light weight pistons / con-rods, the second-order vibration is greatly reduced.
  #35
Old 03-07-2010, 03:40 PM
Bigrigger's Avatar
Bigrigger has a spectacular aura aboutBigrigger has a spectacular aura about
Thank you very much pete95, that answers my question perfectly.
  #36
Old 03-07-2010, 07:18 PM
997tt RS 2.7's Avatar
997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of997tt RS 2.7 has much to be proud of
Originally Posted by Serge
This engine was developed in house by RUF and is not based off any current Porsche engine.
More info here: http://www.motortrend.com/auto_shows...t_8/index.html
542 SAE hp-180-degree flat plane crank-8500 rpms-same ht. only .08 in longer than 3.8L boxer-88lbs less weight than 3.8L-"high pitch" exotic sound @ full throttle what's not to love Oh almost forgot "DRY SUMP" lube can be mounted lower (center gravity) with new transmission design only hiccup >$300K
  #37
Old 03-07-2010, 07:22 PM
McLaren Automotive explains this; has to do with cylinder in phase/out phase? makes a "shreik" exhaust note (ala Ferrari)
  #38
Old 03-08-2010, 04:50 AM
911A4Mustang's Avatar
911A4Mustang is infamous around these parts
v8's and Porsches!
V8's and Porsches, two of my favourite things. Wow what a feat, the guys from RUF have managed to shoe-horn a 4.5L V8 into the back of a 911!!!! Only thing they could do to top this is to help my gf pack her belongings into 1 suitcase for a 1 week vacation.
Would love to hear this!
  #39
Old 03-08-2010, 07:08 AM
hdpt73's Avatar
Registered PM
hdpt73 is infamous around these partshdpt73 is infamous around these partshdpt73 is infamous around these parts
Simply Amazing
This technology has been out for a while now with the GM V8s. Too bad it's priced where only very few people could afford it. Now all Porsche AG needs to do is buy this car, reverse engineer it and sell it cheaper. Amazing car though.
  #40
Old 03-08-2010, 06:51 PM
JAMS's Avatar
JAMS is infamous around these parts
Let's be real. 1 suitcase/ 1 week... even RUF has it's limitations!
  #41
Old 03-08-2010, 11:56 PM
Verde's Avatar
Verde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond reputeVerde has a reputation beyond repute
Spectacular. The only disappointment is that they didn't place the engine in front of the axle and the gearbox further aft. A mid-engine, flat plane crank, V8 911. Gosh.
  #42
Old 03-10-2010, 09:55 AM
hesperus's Avatar
hesperus is just really nicehesperus is just really nicehesperus is just really nicehesperus is just really nicehesperus is just really nice
video interview with Alois Ruf on the car and new engine
http://www.youtube.com/watch?v=-rOZKep8Drc
  #43
Old 03-10-2010, 12:00 PM
pfan12000's Avatar
Cool vid, thanks for sharing.
  #44
Old 03-10-2010, 03:56 PM
luis_102's Avatar
luis_102 is infamous around these parts
amazing, love the color
  #45
Old 03-10-2010, 04:22 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Does anyone know when it will be tested by a magazine? I would love hear the writer's impressions.
Quick Reply: Ruf RGT-8...live from Geneva!
