How to Raise Rear of Car
Hey guys,
I'm going to be swapping out my rear rotors this week and am unsure how to get a set of jack stands under the rear jack points. Where do I jack up the car so that it leaves the jack points free to place the stands under?
Pics would be a huge help if available.
Thanks,
Kush
Thanks,
Kush
Hey guys,
Thanks,
Kush
Thanks,
Kush
It might be helpful to drive the rear tires up on wooden boards to give additional room to access the undertray fasteners and get the jack under the motor.
I would be cautious in just jacking up the rear. 4 point jacking would be much more safe. The following is a link to the method I use. Granted, it's on a 996, but the jacking procedure is the same. I don't use the 2x4's (and you may not need them either) because my jack clears without them:
http://forums.rennlist.com/rennforum...p-a-p-car.html (scroll down to about mid page for the photos and explanation)
Hope this helps!
Hope this helps!
You can jack the rear from the cross member mentioned near the sway bar. You will need to drive the rear onto a low ramp or 2x10 or something to gain clearance for the jack. And the engine case will work also. You can also jack up each rear corner at the jack point, then place a jack stand at the cross piece to which the lower control arm attaches, near the junction of the two. But frankly, since you will not need to be under the car, you can just work with a jack at each corner. If you need to get inside the wheel well to locate anything, then for safety, you should place a jack stand at the cross member mentioned near the LCA attaching point.
Thanks to others for actually helpful replys.
Sorry for giving you the instructions directly from a Porsche service manual. I guess Porsche trained technicians must be a lot stronger then you. If you can afford a gt3 you can afford to have someone work on it since you obviously haven’t ever worked on a car before. Don’t forget righty tighty lefty loosey. That’s how you work a bolt!
I guess the ability to afford a GT3 is no proxy for mechanical ability nor the ability for two objects to occupy the same space simultaneously.
I just don’t understand the logic here. Lifting a car properly is the 2+2 of the mechanical realm. If you cant answer that problem, and your asking for algebra, your asking for trouble. The best advice here was not to try it. Brakes are kind of important, as is safety when lifting and working on a car. While I realize everyone has to start somewhere, don’t do it on your gt3.
Read the original post and you'll see I wasn't asking where the jack points are. Since you can afford a GT3 you should be able to figure out its bit difficult to place a jack stand on the jack point when its being used by the jack to raise the car in order to place a jack stand under it. Maybe you could also direct me to the page in the manual as to where the throttle is. That would be just as helpful.
The answer is 4 incase that was getting to you to.
As it's now been answered by the more astute, I'll let you have the final word. Have a good night.
check out this post. It has a good picture, about three in, that shows the jack under the engine. This will allow you to put thte jack stands on each side. I also chock the front wheels when both rears are off the ground.
https://www.6speedonline.com/forums/...my-engine.html
