corner balancing-need help!
Maybe we do... but lots of trackday guys think that corner balancing a car will improve handling because weight is 'better' distributed. This is a misconception. Changing spring preload does not change where mass is positioned in the car, and will not produce the same handling changes as actually moving the CG. In some cases it can even produce an opposite effect (ie you setup the car 'heavy' on the rear and then lose rear grip).
calexand
11-05-2015 01:05 PM
WheelsupZR1
10-20-2015 08:36 PM
s6spd
10-06-2015 08:20 PM
alpha motoring
10-02-2015 12:04 PM
