any suggestions for reasonable upgrade to sound system in 996tt
I assume some of you have upgraded the crappy speakers/amp in your 996tts. I have a the non-bose system (no sub). Does anyone have any reasonably priced suggestions for speakers/amps that will fit the rediculously small area allotted in the car to get at least half-way decent sound. I'd rather not spend $10K on the sound system (I already have a decent head unit), when the money could be better spent on more performance oriented mods.
Install Mb quart component speakers, and a Jl w7 8inch sub. Run the Jl sub off a Jl 500/1 amp and then use a 4 chanel for the speakers. Check out www.woofersetc.com for the best prices.
-Daniel
-Daniel
Originally posted by msindi
Get a loud exhaust - then you dont need sound system since you cant hear it
If you really want to install a system, go with mpwrmodena’s idea, good set up. I would maybe go with PPI amps, but the Mb quart and JL setup is very nice.
Yeah I put the Jl and Mb quart running off an apline head unit in a c2 turbo. It sounded amazing in that car, should be the same in the 996. If you want the best and exact setup I used Please Pm me and I will give you a list along with prices.
-Daniel
-Daniel
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
joseph_number1
07-19-2018 05:45 PM
