stock tires?
Old 01-23-2011 | 08:42 PM
moester76's Avatar
moester76 is infamous around these parts
stock tires?
when should I change the rear stock tires on a 2010 GT3...never tracked...had about 11k on it...looks to me like they are starting to wear out but i'm not used to changing tires @ 11k...
My old cayman I think I changed every 20k or so..
thanks.
Old 01-23-2011 | 08:50 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Assuming they're MPSC's, they're more than likely done at 11K miles. Pics would help.
Old 01-23-2011 | 09:17 PM
JEllis's Avatar
JEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond reputeJEllis has a reputation beyond repute
Yep... even PS2's are starting to wear pretty good at 11K if you drive hard.
Jason
Old 01-23-2011 | 09:27 PM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
If you're at the wear bars then its probably safe to say you need a new set. Like bonehead said.. PICS
Old 01-24-2011 | 03:37 PM
moester76's Avatar
well I guess its not unheard of then...just not used to changing them out so soon...I do drive hard most of the time...
Will try to post pics if I can get some good quality pics on here....
if I do change them out..any suggs on replacement?? I haven't tracked the car yet..but I do plan on maybe tracking it once or twice a year?? does that change which ones I should get?? what If I dont track it??
thanks..
Old 01-24-2011 | 04:21 PM
Misanors4's Avatar
Look into the Bridgestone Re-11. They are a great tire for both wet and dry performance that you can also use at the track. They are much cheaper then the PS2 or MPSC also.
Old 01-24-2011 | 05:46 PM
10GT3's Avatar
10GT3 is infamous around these parts10GT3 is infamous around these parts
personally, can't imagine getting 11k out of a set of mpsc's. most i know get around 5k or less. mine lasted 5k with no track days at that time. switched to re-11's and have about 13k and the rears about to need replacement. re-11's are much cheaper and are great street tires, dry or wet. as noted above, good on track also.
Old 01-24-2011 | 08:41 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Also check out the new Toyo Proxes 1. High end street sports car tire.
Old 01-25-2011 | 06:29 AM
brownan's Avatar
brownan is a jewel in the roughbrownan is a jewel in the roughbrownan is a jewel in the rough
RE-11s are cheap and decent but very heavy and not N rated. I've got a set on my Turbo and done maybe 10k plus a few track days in the rain. They still look great. The weight is suboptimal though.
Old 01-25-2011 | 04:10 PM
KBS911's Avatar
KBS911 is infamous around these parts
Exactly. If you have 11K miles count yourself lucky. Very lucky. I have 11.5k on my 10 GT3 and am on my second set of Cups, ready for a 3rd and recently went to a set of PS2's on GMG wheels for street use.
Old 01-26-2011 | 10:07 AM
20C4S's Avatar
thanks.
don't wait til last minute to change them. sounds like they're shot. get some new shoes on asap.
Old 01-27-2011 | 01:35 PM
moester76's Avatar
thanks guys.
got her an appointment this saturday.
gonna get her new shoes and they are gonna look at my clutch problem too...hope its minor.
Old 01-31-2011 | 02:48 PM
moester76's Avatar
I set a new record with 11k on MPSC tires at the dealer.
I'm looking for an alternative to the MPSC since I dont track the car that much.
The ps2's according to the dealer will be discontinued in 6-12 months...which could pose a problem in the future if I need to replace just one tire with balance issues.
He recommended the pirellis' P0 tires...has anyone heard of these tires? are they good street tires? Im looking for something thats N rated.
thanks..
Old 02-01-2011 | 01:30 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
getting 11k out of mpsc must be longevity record especially if you drive hard. the other oem N spec tire for gt3 is perilli corsa system but i heard these are being discontinued as well. they should last a bit longer than mpsc. although 11k is hard to beat.
The_Ruski_Driver
10-25-2015 08:40 PM
horsepowerfarm
09-10-2015 06:09 PM
The Oss
08-24-2015 08:19 PM
Zero911
08-24-2015 06:51 PM
Glasig
08-23-2015 03:35 PM
Quick Reply: stock tires?
