recommendations on camber kits
Old 01-24-2011 | 06:53 PM
997gt3LA's Avatar
997gt3LA is infamous around these parts
997.1 gt3 lowered on original coils want to fix my camber it's eating up my tires. I've heard fixing the camber will reduce my handling because the cars original specs are Cambered any ideas. Thanks
Old 01-24-2011 | 07:46 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
lowering the car increases negative camber... but you need to get upgarded upper control arms (DOG BONES) to get the correct geometry when you lower the car.
If the tires are not wearing even its an alignment issue.. take it to a reputable shop and tell them to fix it..
BBI Autosport
Stuttgart Performance
GMG
all close to you and amazing shops!
Old 01-24-2011 | 08:39 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Negitive camber is not what really eats up the tires....too much toe eats up the tires.
You can run zero toe up front and .14 toes int eh rear and you will find your tires wear much better. Plus you can keep the stock negitive camber settings for your GT3.
Just so you know....I run -2.5 front and -1.9 rear with zero toe front and no mor than .16 degrees toe rear. I drive my car a lot on the street and my street tires at 17k miles look like they can go another 17k miles. Again is all in the toe more than the camber settings that eats tires.
Old 01-24-2011 | 11:26 PM
997gt3LA's Avatar
Wow that's Awsome info guys thanks alot
Old 01-26-2011 | 09:24 PM
jurnes's Avatar
jurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond reputejurnes has a reputation beyond repute
I talked to TPC (the provider of my swaybars) Rear camber should be adjusted via the eccentric bolt on the inboard side to the LCA. Leave the dog bones at stock length. Plenty of adjustment available this way w/o messing with the dog bones. (I am running 2.1 neg camber with more on tap if needed.
Check toe settings: should be 0% front and about 1.5mm per side in the back
orbelo
08-30-2015 12:26 PM
The Oss
08-24-2015 08:19 PM
OldBoldPilot
08-24-2015 04:00 PM
08-21-2015 06:34 AM
TrackOne
08-20-2015 12:56 PM
Quick Reply: recommendations on camber kits
