What is the advantage of the centerlocks?
It seems like the centerlock wheels are a big liability. Tire changes seem like they will be difficult and even at the track, changing wheels will require an engineer to be present.
I am sure for a pit crew they are ideal but for a mostly street car and an amateur track car there are more risks that something will go wrong with them than a standard wheel.
They do look better but that should be secondary to the other issues.
I remember the Porsche website claims that the center lock wheels reduce rotating masses for better driving dynamics (as well as the wheel hubs, if I remember correctly.)
Regards,
Regards,
All advantages of centerlock wheels flow directly to Porsche. When the added weight of the adaptors required is considered, BS "rotating mass improvement" vaporizes. Then there is the marvelous "advantage" of TWO people required to CHANGE A TIRE(!!), big ol' breaker bar required to un-do CL nut, big ol' torque wrench required to do up CL nut....well, here's your sign.
so, i find tedium when undergoing 4x5x2 = 40 bolt tightening/loosening events when changing set of wheels from street to track.
how bad is it to make this 4x1x2 = 8? how much worse is this bolt than a normal bolt? does it need 2 people? and why?
thanks!
thanks!
Center locks were developed in racing and have been used there for decades.
No doubt you can remove 1 lug faster than you can remove 4 or 5.
This racing technology has progressed to road cars now.
It has been on road cars that were used for racing as far back as 50 years ago.
Think FORD GT with knock offs and not mention earlier racing british cars.
Centerlock wheels are also generally stronger than a wheel with 4 or 5 lugs.
So is there an advantage yes.. What does it really matter on a street car used on public roads? Hardly anything.
The good thing is that racing technology is progressing to road cars and we all benefit from it.. ( atleast in road racing and other forums) minus our friends in nascar lol..
5 lugs and steel wheels........... LOL
Just think back.......... Remember when aluminum wheels were introduced people thought some companies were nuts.
cool, thanks.
question remains: some people say that 2 people are required to deal with these bolts. is this true?
if these bolts are as easy as the others, then i don't see any problem as it saves time where it takes me an hour to change 4 wheels with analog equipment.
i work solo.
i work solo.
cool, thanks.
i work solo.
i work solo.
You can do this yourself just requires a proper torque wrench..
