Schroth Harness
Schroth Harness
I was wondering if the 6 Point Schroth harnesses are comfortable enough for street use? Other than convenience, is there any reason NOT to have them for mainly this purpose?
Unless you get into an accident (God forbid) then there is no issue... If you ever do wearing harness then it may put too much stress on your neck at impact.
Same reason you should wear Hans with your helmet & harness.
I have both harness and seat belts for track and street driving purposes. The seat belts are 2.5 lbs per side, let it stay in the car
You don't have to remove it.
I believe the dealership can fix that. In my old C2S it was beeping when I got on the track,but after the engine was replaced it never did it... I guess the dealership shut it off.
And the GT3 doesn't do it either
I also kept the factory seat belts when I installed my harness. On the street I use the factory belt + the lap belts of the harness (because I don't want the harness buckle dangling free). To keep the seat belt warning from going on when you use only the harness on the track, you can insert a dummy buckle piece into the factory seat belt receptacle. For example, see http://pkvista.com/TraqJunk/Index.html. You can get cheaper versions of the same type of thing on eBay (mostly from China).
I also realize they are not DOT approved, but that is not the issue I am curious about.
I am not sure what the deal is with that. I would like to hear more detailed information on this subject. By trade I am a helicopter pilot, and I have flown many types. Most have 5 point harnesses, and at a minimum, 4. When aircraft crash, there are tremendous G-forces generated, in a variety of possible directions. Additionally, there is an endless amount of meticulous, ongoing research about crash sequences and survivability. If a three point harness was in any way superior in a crash, I am sure the entire military would be using them to protect their million-dollar-pilots. I don't have much track experience, so I would love to hear the logic of track crashes versus road, and why a 5 or 6 point harness is hazardous on the street.
I look at safety as a system: [3pt/CG lock/air bags] or [Cage/helmet/harness/hans]
Ultimately you must decide which system is best suited for your driving.
Schroth installation instructions with crash test data: http://www.schrothracing.com/docs/Co...structions.pdf
Thanks for the link and the response. I read the manufacturer's data. It looks like a lot of lawyer talk regarding liability. I found their actual crash data insufficient in specifics for a comparison of restraint systems versus crash scenarios and injuries. My understanding of one actual reason for not being street legal is because DOT requires all DOT approved seat belts to be released with a push-button release, I suppose because they assume police, and fire/rescue couldn't possibly be smart enough to figure out more than one type of seat belt release mechanism. My guess is this was written by someone with a background in State of Virginia government.
Anyway, my search for facts continues...
